Passenger Side Window Problem
Old Aug 4, 2005 | 08:27 PM
brucksch's Avatar
brucksch
Default Passenger Side Window Problem
I noticed that from time to time my passenger side window will not operate. Recently it decided to stop working at all. Is this a common problem?
Old Aug 4, 2005 | 08:41 PM
istsme98's Avatar
istsme98
just had the power motor or modulator replaced in mine last week. had the same problem as yours
Old Aug 4, 2005 | 08:45 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Unfortunately it is a fairly common problem among C5's. You may need to replace the window regulator. Here's a link.
http://www.ecklers.com/product.asp?d...PGLF8C5BW2BPB8
Paul
Old Aug 4, 2005 | 09:28 PM
Lowcash's Avatar
Lowcash
I had my drivers side window regulator replaced soon after I bought my C5.
Old Aug 4, 2005 | 09:38 PM
GrayC5's Avatar
GrayC5
You might give the following from C5 Tech Tips a try: Possible remedy for a stuck window.
Otherwise, you'll most likely need to replace the window regulator and motor assembly. Good luck.
Old Aug 4, 2005 | 09:58 PM
'99 Feather's Avatar
'99 Feather
This has happened to me a couple of times and the technique listed in the link has worked for me every time. Now I make sure I lower the passenger window every time I get in the car. I haven't had any problem since.
Old Aug 4, 2005 | 10:03 PM
Rob'sC5's Avatar
Rob'sC5
Cruise-In V Veteran
St. Jude's Donor '05
Not to hijack this thread but my window goes down and up but the door will not unlock using the key fob or the control on the drivers side. I have to manulaay flip the lever.
Old Aug 5, 2005 | 07:33 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Common problem with ALL GM cars.
Hold the button in the down position as you slam the door closed. SLAM that door like you're mad at it. With any luck the window will start working again for a while.
Tom
To Passenger Side Window Problem
