Grond gets a valvetrain upgrade
Supporting Tuner
Look what I just bought! Harland Sharp 1.7 Roller Rockers WooHoo
Supporting Tuner
Originally Posted by Stangkiller
sweeeeet, but why the upgrade?
Chris
Chris
With the big cam, I want all that lift and duration to actually make it to the valves.
Stephen
Originally Posted by EnglandGreen
You have seen the stock stamped steel valvetrain, it borderline at best. It moves all over the place - like wearing a cheap suit.
Stephen
Stephen
Although I'll stick with stock rockers for awhile...I don't think the $$$ right now is worth the very lil gain for me..
Take care!
Steve
Supporting Tuner
I'm looking for the stability and to be able to redline at 7000rpm. I'm at 6800 right now....
Cruise-In VII Veteran
thats sweet EG................. You need a good vacation down here in Mississippi............... Maybe this winter.............. you can do some of your fancy wrench work on ole "Dallas"
Supporting Tuner
Supporting Tuner
Originally Posted by DaBoz
EG... with all the work you've done, what kind of HP numbers are you looking at now???
Gears/stall are coming after Carlisle
With the very conservative tune from Slowhawk of Dez Racing, it dynoed at 384rwhp, 364rwtq. Gears, a stall and a retune will push that number to over 400rwhp.
Sweet you ole' ZZ.....
Location: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Those look great Stephen Like some else said, too bad you don't have Lexan covers
