removing 3rd brake light
Old Aug 18, 2005 | 01:22 AM
eec8059's Avatar
eec8059
Default removing 3rd brake light
Anybody know how to replace the brake light?
I'm guessing 1 of the taillights would have to be removed?
Any help?
-Thx
Old Aug 18, 2005 | 01:56 AM
scottsdaleslim's Avatar
scottsdaleslim
Navigator
That little sucker is hard to reach, I doubt you can get it from below. You need to remove the panel at the rear of your hatch, which is no big deal - take the covers off the 2 side storage compartments, then loosen the corner panels that will free up the panel in the middle enough to come out. You still need to do some reaching but you can get it out at least.
There are 2 small thumbscrews attached to the top of the light, one at each end. As I recall the screws don't have to come all the way out, just loosen them and the light can slide out ( I *think*). If the lights bad I think you need to replace the whole thing, it's got an array of small red bulbs and I think I remember the bulb housing being permanently attached (glued) to the lense/cover. Good luck.
Old Aug 18, 2005 | 02:09 AM
gairno's Avatar
gairno
Any help?
-Thx
This is the way that I would go. I even read somewhere that to replace the 3rd brake light was to remover the tail light. Good luck.
Old Aug 18, 2005 | 11:19 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I just simply removed a tail light to get mine out.
Old Aug 18, 2005 | 12:55 PM
Take one of the two inner taillights out and you can get access to the 3rd brake light.
Old Aug 18, 2005 | 02:17 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Yup! that's the easiest way!
Old Aug 18, 2005 | 02:30 PM
Patches's Avatar
Patches
Removal Procedure
1] Remove one of the inner tail lamps. Access the high-mounted stop lamp through the tail lamp opening.
2] Disconnect the electrical connector from the stop lamp.
3] Remove the screws retaining the stop lamp to the rear fascia.
4] Remove the stop lamp from the vehicle through the tail lamp opening.
Installation Procedure
1] Install the high-mounted stop lamp into position inside the rear fascia.
2] Loosely install the stop lamp mounting screws.
3] Align the stop lamp to the rear fascia, then press and hold the lamp to the fascia for flushness. Tighten the high-mounted stop lamp retaining screws to 4 N·m (35 lb in).
4] Connect the electrical connector to the stop lamp.
5] Install the inner tail lamp.
Old Aug 18, 2005 | 03:12 PM
eec8059's Avatar
eec8059
Thanks guys for sharing your knowledge. This info is very helpful.
I'm ready to face the task.
To removing 3rd brake light
