20inch front and rear wheels on a C5 or Z06?!!!!!!!
your car is looking good man
i have 20inch front and rear right now but it is stock height
and i am looking to lower it
just trying to see if anyone else had done it also and lowered it
Guest
Posts: n/a
what brand and width are they??
i had 20's all around on my c5 but the fronts scraped. even with 35 series tires. i messed up the rims and put the stock rims back on.
do yours scrape in the front?
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
You should be able to run a 245/30/20 or 255/30/20 on the front w/o any probems.
These are as far as I know, the only real suitable sizes for a C5 front app.
I think 20's look too big for the front fender openings though. Big is cool, but only to a point. Bigger than that looks like
they have 245/30/20
but i am not sure if i will when lowered
St. Jude Donor '03
they are on a Z06 and i have no rubbing right now
If those are the correct sizes you have, you should be able to slam it with no problem...those tires are about the same height as the stock 17's.
does anyone have any pics and people
that have tried it ?
Guest
Posts: n/a
i am going to try it then
Good Luck!
Originally Posted by dajael
Doubt you're going to find anyone around here with 20's on all 4 corners, most of us run 19/20's, 18/19's or 18's all around...but I think you should give slamming it a try. you can always reverse it if they rub. I'd be curious to see the result, certainly would'nt have much front wheel well showing which will probably look pretty good.
Good Luck!
Good Luck!
and i will keep you guys posted
thanks
Yes they fit
i have front and rear 20 inch only rub if im really turning hard corvette told me the front wheel will lock up but ive had mine 180 plus no problems
Received 19,284 Likes
'20-'21-'22-'23-'24
Closing this 12 year old thread. If you want to discuss 20" wheels, post up a new thread.
