Sway bars
Old Sep 26, 2005 | 05:06 PM
TAGVETTE's Avatar
TAGVETTE
Default Sway bars
I have a 2002 Quicksilver. I don't know the suspension, but I was wondering:
What is difference between the Z51 sway bars and the Z06?
Old Sep 26, 2005 | 05:49 PM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Copied from the Weights, measurements, ratios, strengths, etc. sticky thread at the top of the forum...
Swaybars
23mm, front; 19.1mm, rear --- FE1/Base --- Source
25.4mm, front; 21.7mm, rear --- FE3/Z51 97-99 --- Source
28.6mm, front; 23.6mm, rear --- FE3/Z51 00-04 --- Source
30.0mm, front; 23.6mm, rear --- FE4/Z06 --- Source
31.75mm, front; 25.4mm, rear --- Hotchkis --- Source
38.4mm, front; 27.5mm, rear --- GM T1 --- Source
Old Sep 26, 2005 | 10:22 PM
Last C5's Avatar
Last C5
As far as the handling goes, I went from the Z51 front bar to the Z06 bar and the difference is subtle but noticable. Worth the investment.
Old Sep 27, 2005 | 01:09 AM
ducatidave's Avatar
ducatidave
I went from the F55 suspension to the T1, huge handling improvement on a vert. Eliminates the body roll.
Old Sep 27, 2005 | 07:05 AM
Dark-Knight's Avatar
Dark-Knight
Z06 sways are vast improvment over stock, no more body roll.
Old Sep 27, 2005 | 10:34 AM
TedDBere's Avatar
TedDBere
Here's a visual of the differences...stock on top, Z51 in the middle and Z06 front bar on the bottom. Stock rear bar on all of them (Thems the rules so don't ask why the rear bar!):
To Sway bars
