Dual Heater Help Please
Old Oct 1, 2005 | 03:51 PM
mustard's Avatar
mustard
Default Dual Heater Help Please
On a '04 How warm should the passenger side get if the drivers side is set to 65? I called the dealer but the service manager acted like he didn't know anything about the dual controls. He said it should be as warm as the drivers side. Kinda defeats the purpose of the dual heaters. thanks for you help
Old Oct 1, 2005 | 05:43 PM
Antvette's Avatar
Antvette
Veteran: Marine Corps
Hmmm. Never thought about it. I'd say a good 15-20 degree difference.
Old Oct 2, 2005 | 09:38 AM
davee01's Avatar
davee01
For some reason I seem to remember that the passenger adjustment is 5 or 10 degrees up or down from the driver side. not sure if I read that here, or in the manual.
Old Oct 2, 2005 | 10:22 AM
steve8's Avatar
steve8
Without looking in the manual, I believe if you set the passenger dial in the middle it will be the same as the drivers side. Lower is cooler, higher is warmer.
Old Oct 2, 2005 | 12:43 PM
mustard's Avatar
mustard
Default Dual heaters
If the drivers heater is set in the 60's the passengers side doesn't get much warmer. The manual says it should be warmer but not by how much warmer it should be
Old Oct 2, 2005 | 12:47 PM
mustard's Avatar
mustard
If I set the passengers control in the middle it is as warm as the drivers. If I turn it to cooler it gets colder but if I turn it to warmer it doesnt get very warm. I would like to know how warmer its supposed to get
To Dual Heater Help Please
