History Request
1G1YY32G1Y5120226 - mtjulietdba@yahoo.com
Thank you in advance!
Robert
VEHICLE INFORMATION
Merchandising Model : 1YY67 -2000 CORVETTE CONVERTIBLE Warranty Start Date : 04/12/2000
BARS Order Type : 90 - SPEC-EVENT USED CAR (CVMS USE)
Delivering Dealer : CHUCK HUTTON CHEVROLET CO.
2471 MT MORIAH RD
MEMPHIS , TN 38115-1594
(901) 365-9700
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/14/2003 510084 # N2700 - SWITCH, STOP LAMP - ADJUST 6894 miles
01/14/2003 510084 # D1322 - MOTOR AND/OR FAN, BLOWER - A/C - R&R OR REPLACE 6894 miles
02/24/2000 419045 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 3 miles
02/16/2000 418364 # E0400 - LOCK, WHEEL - REPLACE 3 miles
02/16/2000 520226 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 3 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1665 kg (3671 lb) Order Number : CFDW19
Build Date : 02/10/2000 Build Plant : 1Y5Y - BOWLING GREEN
OPTION CODES
AG2 - SIX-WAY POWER PASSENGER SEAT AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS
AQ9 - SEAT FRT BUCKET, PASS, DRIVER BGR
B34 - COLOR-KEYED FRONT FLOOR MATS -CARPETED B84 - BODY SIDE MOLDINGS
C05 C60 - AIR CONDITIONING
DL5 - ROADSIDE SERVICE INFORMATION DECAL DL8 - HEATED REARVIEW MIRRORS
FE1 - SUSPENSION SYSTEM-SOFT RIDE FE9 - FEDERAL EMISSIONS
GU6 - REAR AXLE 3.42 RATIO IL3
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63
LS1 MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION NF2 - FEDERAL EMISSION SYSTEM
NK4 - LEATHER WRAPPED STEERING WHEEL QF5
T82 - TWILIGHT SENTINEL HEADLAMPS T96 - FOG LAMPS
UN0 - AM/FM STEREO W/CD PLAYER UV6
UZ6 U52 - ELECTRONIC INSTRUMENTATION
U75 - POWER ANTENNA VM3 - CONSUMER INFORMATION LABEL
V49 V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG YGH
1AA - RETAIL AMENITY DELETE 1SA - OPTION PACKAGE 01
19I - INT EBONY INTERIOR TRIM 193
41T - BLACK CONVERTIBLE TOP 70U - TORCH RED
Thanks for doing this! It has to be a great help to fellow CF members
To Sponge Vette: Thanks so much! Looks like I started an avalanche here, sorry I didn't mean to.......
Thank you.
Here ya go:
VIN : 1G1YY22G525126158
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2002 CORVETTE COUPE
Warranty Start Date : 05/07/2002
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer :
BOWE CHEVROLET-OLDS-BUICK, INC.
PO BOX 307
MEDICINE LODGE , KS 67104-0307
(620) 886-5622
Selling Source : 13 - CHEVROLET
Site Code : 05526
Business Associate Code : 112077
04/06/2005 059954 # C0182 - REGULATOR, FRONT DOOR WINDOW - RIGHT POWER - R&R OR REPLAC 17220 miles
04/06/2005 059954 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 17220 miles
02/02/2005 056373 # C3358 - TRIM ASSEMBLY, FRONT DOOR - LEFT - ONE PIECE - R&R OR REPL 16756 miles
02/02/2005 056373 # H2505 - MODULE, ELECTRONIC BRAKE AND/OR TRACTION CONTROL - FOUR WH 16756 miles
12/22/2004 054135 # C9041 - BELT, SEATBELT RETRACTOR (FRONT) (LEFT) - REPLACE 16414 miles
11/30/2004 052972 # L1200 - SENDER AND/OR PUMP ASSEMBLY, FUEL (TANK UNIT) - REPLACE 16297 miles
11/30/2004 052972 # N9995 - CUSTOMER CONCERN NOT DUPLICATED 16297 miles
01/19/2004 035097 # N4920 - MODULE, LOCAL INTERFACE UNIT - DOOR - RIGHT - REPLACE 13069 miles
01/19/2004 035097 # C3358 - TRIM ASSEMBLY, FRONT DOOR - LEFT - ONE PIECE - R&R OR REPL 13069 miles
01/19/2004 035097 # C1420 - WEATHERSTRIP, HATCH OR FRONT ROOF PANEL - RIGHT - REPLACE 13069 miles
03/31/2003 018631 # N3215 - ACTUATOR ASSEMBLY - DOOR LOCK - LEFT FRONT - REPLACE 8789 miles
03/31/2003 018631 # J0667 - BELT, PRIMARY ACCESSORY DRIVE - REPLACE 8789 miles
03/31/2003 018631 #L1200 - SENDER AND/OR PUMP ASSEMBLY, FUEL (TANK UNIT) - REPLACE 8789 miles
10/14/2002 009509 # J1200 - CRANKSHAFT - REPLACE 6703 miles
10/14/2002 009509 # C0101 - GLASS, FRONT DOOR - LEFT - ALIGN 6703 miles
10/14/2002 009509 #B3775 - ASSEMBLY, CONVERTIBLE TOP - REPLACE 6703 miles
06/27/2002 003041 # N0110 - BATTERY - ONE - REPLACE 3667 miles
03/22/2002 A26158 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VIN 1G1YY22G525126158
VEHICLE BUILD
Gross Vehicle Weight Rating : 1664 kg (3669 lb)
Order Number : FBCQ05
Build Date : 03/22/2002
Build Plant : 125Y
OPTION CODES
AAB - MEMORY PACKAGE
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM
AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT
CF7 - REMOVABLE SUN ROOF
CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV
DD8 - OSRV
D42 - REAR COMPARTMENT LUGGAGE SHADE AND PARCEL NET
FE3 - SPORT SUSPENSION
FE9 - 50-STATE LOW EMISSION VEHICLE
IL3 - TRIM INTERIOR DESIGN-AQ9
K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP
NB8 - CA/NORTHEAST EMISSIONS OVERRIDE
NF7 - FEDERAL EMISSION SYSTEM NLEV
N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT QF5 - POLISHED ALUMINUM WHEEL
SLM - STOCK ORDERS
T96 - FOG LAMPS
UV6 - HEAD UP DISPLAY
UV7 - WINDSHIELD ANTENNA
UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
V49 - LICENSE PLATE FRAME
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XGG - FRONT TIRE-P245/45ZR17 BW SBR
YGH - REAR TIRE-P275/40ZR18 BW SBR
Z51 - PERFORMANCE HANDLING PACKAGE
1SC - CORVETTE COUPE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * LUGGAGE SHADE AND PARCEL NET * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN
19I - BLACK INTERIOR TRIM
193 - BLACK LEATHER TRIM SEATING
21U - ELECTRON BLUE METALLIC
Thanks,
VEHICLE INFORMATION
Merchandising Model : 1YY37 -2001 CORVETTE Z06
Warranty Start Date : 09/14/2000
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer :
CLASSIC CHEVROLET, LTD.
PO BOX 1717
GRAPEVINE , TX 76099-1717
(817) 421-1200
11/09/2004 280251 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 11037 miles
09/06/2000 A05959 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Thanks for the nice clean service history...alot easier to paste.
VIN 1G1YY12S415105959
VEHICLE BUILD
Gross Vehicle Weight Rating : 1611 kg (3552 lb)
Order Number : CRDH96
Build Date : 09/06/2000
Build Plant : 115Y - BOWLING GREEN
OPTION CODES
AR9 - BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
DL8 - HEATED OUTSIDE REARVIEW MIRRORS
FE4 - RIDE & HANDLING SUSPENSION SYSTEM
IP4 - TRIM INTERIOR DESIGN - AR9
LS6 - 5.7L LITER SFI V8 - 385HP
M12 - 6-SPEED MANUAL TRANSMISSION WITH OVERDRIVE
QE1 - ALUMINUM WHEEL
U73 - FIXED MAST ANTENNA
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA XFW - FRONT TIRE-P265/40R17
YFU - REAR TIRE-P295/35R18
1AZ - SOLD ORDERS PROC OPTION
1SA - CORVETTE Z06 BASE EQUIPMENT GROUP 12U - QUICKSILVER METALLIC
194 - Z06 INTERIOR - BLACK
Enjoy!
Thank you.
VIN : 1G1YY32G225124776
VEHICLE INFORMATION
Merchandising Model : 1YY67 -2002 CORVETTE CONVERTIBLE Warranty Start Date : 10/28/2002
Delivering Dealer :
BUD WOLF CHEVROLET, INC.
PO BOX 20606
INDIANAPOLIS , IN 46220-0606
(317) 257-4461
06/24/2004 191111 # H0127 - ROTOR ASSEMBLY - FRONT - BOTH - R&R OR REPLACE 16017 miles
03/16/2002 095878 # Z6999 - PDI RELATED FLUID ADDS 5 miles
03/16/2002 A24776 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 5 miles
Also a nice easy one
VIN 1G1YY32G225124776
VEHICLE BUILD
Gross Vehicle Weight Rating : 1684 kg (3713 lb)
Order Number : DXSXD3
Build Date : 03/11/2002
Build Plant : 125Y
OPTION CODES
C05 - CONVERTIBLE FOLDING ROOF
DD8 - OSRV
F45 - SELECTIVE REAL TIME DAMPING
G90 - REAR AXLE-3.15 RATIO
G92 - 3.15 PERFORMANCE AXLE RATIO
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4-SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
SLM - STOCK ORDERS
T96 - FOG LAMPS
U1S - COMPACT 12 DISC CHANGER, REMOTE
U75 - POWER RADIO ANTENNA
1SC - CORVETTE CONVERTIBLE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN
41T - T0P-BLACK
79U - MILLENNIUM YELLOW W/TINT COAT
VIN : 1G1YY22G015130116
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2001 CORVETTE COUPE
Warranty Start Date : 06/13/2001
Delivering Dealer :
MIKE SHAW CHEVROLET
1080 S COLORADO BLVD
DENVER , CO 80246-2404
(303) 757-6161
05/03/2002 245339 # E0721 - SENSOR, LOW TIRE PRESSURE WARNING - FRONT - LEFT - REPLACE 3942 miles
06/14/2001 208044 # N0120 - CABLES, BATTERY - POSITIVE - BATTERY CABLE - REPLACE 78 miles
05/17/2001 204718 # K1120 - CONTROL ASSEMBLY, FLOOR MOUNTED GEARSHIFT - R&R OR REPLACE 7 miles
05/17/2001 204718 # J4217 - SPARK PLUG - ONE - DIAGNOSTICS WITHOUT REPLACEMENT 7 miles
05/03/2001 A30116 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VIN 1G1YY22G015130116
VEHICLE BUILD
Gross Vehicle Weight Rating : 1685 kg (3715 lb)
Order Number : DFTSR8
Build Date : 05/03/2001
OPTION CODES
C2L - DUAL REMOVABLE ROOF PANELS
DD8 - OSRV
JL4 - ACTIVE HANDLING SYSTEM
SLM - STOCK ORDERS
T96 - FOG LAMPS
1AY - STOCK ORDERS PROC OPTION
67I - LIGHT OAK INTERIOR TRIM
673 - LT OAK LEATHER TRIM SEATING
86U - MAGNETIC RED MET W/ TINT COAT
Thanks in advance!!
1G1YY32G025107605
Thanks in advance!!
1G1YY32G025107605
VEHICLE INFORMATION
Merchandising Model : 1YY67 -2002 CORVETTE CONVERTIBLE Warranty Start Date : 10/11/2001
Delivering Dealer : MIKE ANDERSON CHEVROLET OF OSSIAN,INC.
PO BOX 516
OSSIAN , IN 46777-0516
(260) 622-4115
CLAIM HISTORY
02/23/2005 099056 # V1145 - 04006 - PERFORM REPROGRAM AND FUNCTIONAL TEST - MANUALS ON 13185 miles
09/20/2001 A07605 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1662 kg (3665 lb) Order Number : DKSZM0
Build Date : 09/20/2001 Build Plant : 125Y
OPTION CODES
AAB - MEMORY PACKAGE AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
C05 - CONVERTIBLE FOLDING ROOF DD0 - ELECTROCHROMIC MIRRORS: ISRV & LH OSRV
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
FE3 - SPORT SUSPENSION FE9 - 50-STATE LOW EMISSION VEHICLE
GU6 - REAR AXLE 3.42 RATIO IL3 - TRIM INTERIOR DESIGN-AQ9
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI V8 - 350HP MM6 - 6-SPEED MANUAL TRANSMISSION
MN6 - 6-SPEED MANUAL TRANSMISSION NF7 - FEDERAL EMISSION SYSTEM NLEV
NK4 - LEATHER WRAPPED STEERING WHEEL N37 - STEERING COLUMN - POWER TELESCOPING & MANUAL TILT
QF5 - POLISHED ALUMINUM WHEEL R9Z - POMS EXPEDITE - SOLD ORDERS
SLL - SOLD ORDERS T82 - TWILIGHT SENTINEL
T96 - FOG LAMPS UN0 - AM/FM STEREO W/CD PLAYER
UV6 - HEAD UP DISPLAY UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U52 - ELECTRONIC INSTRUMENTATION U75 - POWER RADIO ANTENNA
VM3 - CONSUMER INFORMATION LABEL V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
Z51 - PERFORMANCE HANDLING PACKAGE 1SC - CORVETTE CONVERTIBLE PREFERRED EQUIPMENT GROUP 2: * DUAL ZONE AIR CONDITIONING * FOG LAMPS * MEMORY PACKAGE * ADJUSTABLE SPORT BUCKET SEAT * POWER PASSENGER SEAT * TWILIGHT SENTINEL * ELECTROCHROMIC MIRRORS: ISRV & LH OSRV * HEAD UP DISPLAY * STEERING: POWER TELESCOPING & MANUAL TILT STEERING COLUMN
19I - BLACK INTERIOR TRIM 193 - BLACK LEATHER TRIM SEATING
41T - T0P-BLACK 79U - MILLENNIUM YELLOW W/TINT COAT
Would you run 1G1YY12S235113366
Thank you so much in advance for your time.
Jimmy
