How much oil usage is normal?
Old Nov 11, 2005 | 07:40 PM
bravastar1's Avatar
bravastar1
Default How much oil usage is normal?
My stock 2000 vert uses about 1 qt of Mobil 1 per 1500 miles. Is this normal?
Old Nov 11, 2005 | 07:47 PM
EdsC6Z06's Avatar
EdsC6Z06
St. Jude Donor '05-'06-'08-'10
GM will say yes, normal. I'd say it's high but there's not a lot you can do about it.
Old Nov 11, 2005 | 07:50 PM
saniterium's Avatar
saniterium
No it is NOT normal at all. My 2000 has gone 2000 miles since I bought it and it has not burned any oil at all (atleast not a noticable amount). Take a look at a 1 qt bottle of oil...it's a TON of oil. If it is burning that much in 1500 miles, then there is something seriously wrong.
Old Nov 11, 2005 | 07:52 PM
DPG's Avatar
DPG
St. Jude Donor '06
according to GM, its normal to burn 1 qt for every 1,000 miles....mine burns more
Old Nov 11, 2005 | 07:53 PM
Patman's Avatar
Patman
It seems to be hit or miss with the LS1. I went 8000 miles on my last oil change interval and the dipstick level did not move the entire time. But yet I know other LS1 owners who add a quart every 1 to 2k.
Old Nov 11, 2005 | 07:55 PM
saniterium's Avatar
saniterium
...so if you went the recomended time without toping off your oil (about 5-7k miles), your engine would be completely dry? You should not need to put 5-7 qts back into the engine in between changes. Where did you actually hear that that crazy amount of oil burn is normal?
Old Nov 11, 2005 | 09:19 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
It's abnormal. I've had my stock 2000 Vert for over two years, put 26k miles on it and have never had to add oil between changes every 6k miles.
Old Nov 11, 2005 | 09:23 PM
JTS97Z28's Avatar
JTS97Z28
I just did an oil change the other day on my 99 hardtop. I went until the DIC said 15% oil life remaning. It was atleast 4,000 miles and mine used 1.5 qts. So I guess mine would be one of the lower consuming LS1's apparently :-)
Old Nov 11, 2005 | 09:49 PM
Oldvetter's Avatar
Oldvetter
My 98 with 92,000 miles has NEVER used ANY oil between 6,500 mile average oil changes !
Old Nov 11, 2005 | 11:48 PM
rws.1's Avatar
rws.1
3000 miles since last oil change and 0 (zero) oil consumption noticeable on the dipstick
Old Nov 11, 2005 | 11:58 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
I have put about 4K miles since my last oil change and it's used maybe 1/2 qt. The engine has seen some hi revs and today I was under the car and noticed a very very slight leak from somewhere between the oil pan and bell housing. btw, it's an '02 with little over 12K miles
Old Nov 12, 2005 | 12:57 AM
Steve's98's Avatar
Steve's98
I never had to add any oil between oil changes on my 98.
Old Nov 12, 2005 | 04:53 AM
c3andc5's Avatar
c3andc5
The LS1 is known to be a little loose and GM will admit that. My 2000 goes down about 1/2 quart every 3K miles depending on how hard I drive her. I check my oil regularily. Your 1 quart per 1500 miles is excessive in my opinion.
Old Nov 12, 2005 | 06:54 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
No, that's not normal consumption. The LS1 can burn some oil and of course your driving habits can contribute to the useage. My '97 with almost 59,000 miles will on occaison require a half quart add between oil changes if I've done a lot of around town spirited driving, but yet I can put her on the highway for a 3000 plus mile round trip and not burn a drop.
Paul
Old Nov 12, 2005 | 06:56 AM
talon90's Avatar
talon90
NCM Ambassador
What? I hope that the GM in your post are the initials of a friend that is just underinformed and not General Motors, if not, you better find another dealer to talk to.
Old Nov 12, 2005 | 09:30 AM
Cajun99's Avatar
Cajun99
I don't know "who" in GM stated that but it's That is not normal.
Guys I know that owned '01s burning oil at that rate had theirs re-ringed.
This FRC is a daily driver with over 136K miles and I generally get 5500-6000 miles between oil changes. I've always kept an eye on the oil level and I have never had to add oil. The level might drop the width of a hair on the dipstick if I've been running the car pretty hard.
I would have major concerns if this car was burning a quart every 1k miles
Old Nov 12, 2005 | 09:50 AM
Len16's Avatar
Len16
I've never had to add oil between changes on my 2000 coupe (24,000 miles).
To How much oil usage is normal?
Old Nov 12, 2005 | 09:54 AM
vert_vette's Avatar
vert_vette
My 2001 has never used oil, I rarely go over 4k RPM
Old Nov 12, 2005 | 10:17 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
Paul
If you do a lot of spirited driving around town that can contribute to some oil burning. But on a trip with some sustained speeds you should burn very little oil. My .02
Old Nov 12, 2005 | 01:09 PM
IMO, this is not normal. My '00 was using a quart every 1200 miles back in 2001 and I had them change the rings under the oil consumption issue. At that time, anything in excess of 1 quart of oil consumed in 2000 miles was considered excessive. Your dealership should have a TSB that covers the oil consumption problem - see what it says. GM may have revised the criteria since I had mine done, but 1500 miles does not seem right.
