Service Column Lock
Old Nov 20, 2005 | 09:20 PM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default Service Column Lock
Lastnight I started my vette while at my buddys house and it said service column lock. It would die every time I started to move. I just installed a K harness about a month ago. It must of went bad. I hooked it up back to stock and it was fine then. My question is should I buy another K harness or just get the CLB? I didn't know which would be better. The k harness didn't seem to be worth a crap. Thanks
Old Nov 20, 2005 | 09:27 PM
Joe's Eray's Avatar
Joe's Eray
I say get the CLB.
Old Nov 20, 2005 | 09:33 PM
J Z06's Avatar
J Z06
Clb
Old Nov 20, 2005 | 09:58 PM
coast7's Avatar
coast7
If you have an MN6, install the CLB ASAP. Can't tell you what to do about the K-harness.
Old Nov 20, 2005 | 09:59 PM
Get the CLB.
Old Nov 20, 2005 | 10:12 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
What they said.
Old Nov 20, 2005 | 10:26 PM
mvvette97's Avatar
mvvette97
i have an automatic.
Old Nov 20, 2005 | 10:34 PM
rws.1's Avatar
rws.1
Sit down, with your back straight you legs crossed and tucked. Close your eyes, holds your arms in front of you about 12 inches from your body and even with your chest. Now breath deeply... in.... out... in ... out... now repeat after me...
CLB....CLB....CLB....CLB...CLB....CLB... .CLB....CLB...CLB....CLB....CLB....CLB.. .CLB....CLB....CLB....CLB...CLB....CLB.. ..CLB....CLB...CLB....CLB....CLB....CLB. ..CLB....CLB....CLB....CLB...CLB....CLB. ...CLB....CLB...CLB....CLB....CLB....CLB ...CLB....CLB....CLB....CLB...CLB....CLB ....CLB....CLB...CLB....CLB....CLB....CL B...CLB....CLB....CLB....CLB...CLB....CL B....CLB....CLB...CLB....CLB....CLB....C LB...CLB....CLB....CLB....CLB...CLB....C LB....CLB....CLB...CLB....CLB....CLB.... CLB...CLB....CLB....CLB....CLB...CLB.... CLB....CLB....CLB...CLB....CLB....CLB... .CLB...CLB....CLB....CLB....CLB...CLB... .CLB....CLB....CLB...CLB....CLB....CLB.. ..CLB...CLB....CLB....CLB....CLB...CLB.. ..CLB....CLB....CLB...CLB....CLB....CLB. ...CLB...CLB....CLB....CLB....CLB...CLB. ...CLB....CLB....CLB...CLB....CLB....CLB ....CLB... CLB....CLB....CLB....CLB... nuff said??
Old Nov 20, 2005 | 10:38 PM
mvvette97's Avatar
mvvette97
So what are you saying? The only reason I went with the K harness was because I heard that the CLB can damage the BCM. Is this true or a load of
Old Nov 20, 2005 | 10:41 PM
sdnet's Avatar
sdnet
I suppose it's possible - in the same way that eating a piece of bad meat can make you very sick. It may happen, but not nearly often enough to avoid doing it. There are more than enough CLB success stories on this board to warrant its use. I suggest installing it.
Old Nov 20, 2005 | 11:03 PM
mvvette97's Avatar
mvvette97
What is the best brand of CLB to get and from where? I noticed that there are differant kinds.
Old Nov 20, 2005 | 11:21 PM
sdnet's Avatar
sdnet
I bought and installed mine over a year ago, so I'm afraid I can't remember where I bought it, although I know it was online. Corvettes of Houston is a reputable shop and sells it. Here's a link for ya:
http://www.corvettesofhouston.com/pr...products_id=54
Here's another one through Mid America, another reputable shop:
http://www.madvet.com/shop?frame=1.58.3998
Old Nov 20, 2005 | 11:34 PM
mvvette97's Avatar
mvvette97
Thanks alot man.
To Service Column Lock
