UPF 46 oil filter
UPF 46 oil filter
Recently the dealer changed my oil and fiter(freebie!). They used a UPF46 (or PF46). Is this the same or better than the UPF44?
Just want to make sure I have the correct filter. If not I'll be swapping it out...
Thanks in advance!
Thanks in advance!
Scientific Negotiator
Received 1,836 Likes
St. Jude Donor '07-'08-'10, '14
That's the one I use.
Thanks in advance!
Thanks in advance!
Originally Posted by DRIVER456
PF-46 replaces PF-44
Received 19,285 Likes
'20-'21-'22-'23-'24
Its the newer version of the 44.
Received 1,674 Likes
I started using the K&N oil filter.
The UPF46 is not the same as the PF46. The UPF is the "Ultraguard" version and according to their filter box information, it is capable of trapping 98% of 8 to 10 micron particles. The "Conventional averge" filter can only trap 40% and the "Premium average" filter can only trap 72%. IF you can believe the claims on the box, this is the filter to use. If you buy them from GM parts direct they are approx $7 ea.
