What does "Theft Lock" mean on the radio?
1 Post
Originally Posted by glerma
I assume it is a theft deterrant...... How does it work?
If the radio is removed from the car, you must enter the code to get it working again. Note that changing/disconnecting the battery may also require entering the code.
I like to set it primarily because once it's set, there is a red light on the faceplate that blinks when the ignition is off, & might deter someone from messing with the car if they think a security system is installed.
Received 19,293 Likes
'20-'21-'22-'23-'24
What he say.
