Installing C6 shifter, have small problem
Old Feb 11, 2006 | 04:51 AM
mkiv808's Avatar
mkiv808
Didn't even think of that.
But I would think that if the vice grips at that force didn't bring it out, what would?
Perhaps not all are created equal?
Either way, I'm loving my new shifter.
Old Feb 11, 2006 | 09:28 AM
grunz95's Avatar
grunz95
I just changed my shifter a few weeks ago. I sprayed a little WD-40 on the piece and waited a few minutes. It came out with no problem.
Gary
Old Feb 11, 2006 | 09:54 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
hi mkiv808 -
Did you get it installed?
I will be doing the shifter in my Z next week - bought a BPP billet unit from a forum member.
I guess it is a crap shoot regarding the locking pin. If I have trouble with mine I intend to drill and tap a hole in it for a 1/4-20 screw, then screw that in and pull on the screw.
best regards -
mqqn
Old Feb 11, 2006 | 02:55 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Originally Posted by mkiv808
The metal "key" in the stock shift ****. I CANNOT pry it out. Even broke a couple chunks off just trying to get it to budge. Im at a loss, any suggestions?
I wheel cut my **** off, and pitched the shifter It is a weak,cheap
pot metal piece
of crap anyway, The aftermarket shifter's are so much better.
I have the Hurst, No regrets.
Old Feb 11, 2006 | 07:13 PM
bennettrp's Avatar
bennettrp
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
Btw, I could NOT get the key out. Vice grips just pulled off more chunks of it. I wound up drilling it out.
What I've seen work, is to grab it with a vice grips, and then pry out with screw driver. Use a thin piece of wood to protect so that the screw driver doesn;t hurt anything.
That's how I did my HURST! Which works super.
D
