2000 Coupe; the rear defroster doesn't work. Anyone have the schematic for it? Or, suggestions on the cause? I've shaken the wires to the hatch posts and nothing. The wires as far as I can see are attached securely.
As in any electrical problem, my option would be:
1- check fuses
2- get an ohmeter and check that the grid is no broken, meanin connect the ohmeter one end to each contact and you must read something more than "open"
3-then I will look for schematics or try to find the switch and test it.
