Serp belt fitting Guide
Can Any help on the de-install and the re-install of the new belt.
Whats the chances of this not fixing my problem?
The main belt drives the alt, water pump, power steering pump.
The 2nd belt drives the A/C compressor.
While you have the belts off, spin the idler and tensioner pulleys on both drive systems (the a/c system has a seperate tensioner)..they should roll smoothly with no resistance. If any seem sloppy, sticky, or otherwise suspect, replace them, they are not expensive and available at any local parts store.
When you have the new belts on, if the squeak remains, look for any wobble in the crank pulley.
If that is ok, the next step I'd do is remove both belts again, then reinstall the main belt only, and listen again. If the squeak went away, your A/C compressor or clutch is the likely suspect.
I think this will help me with a problem im having .when i start the car and drive for the first 15 minutes i hear a noise that sounds like the belt tensioner is squealing . I didnt know there was 2 belts. it must be the a/c belt tensioner.
Guess what???? It still has a bird chirp. That means power steering or alternator (only two items left that didn't get changed)
Good Luck! Can be a devilish problem to find where the noise is really coming from.
