Question for A4 guys
Old Mar 7, 2006 | 03:44 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Default Question for A4 guys
I just noticed this morning that when I shift from drive to reverse, there's a "clickety-click" noise that comes from the rear end that I hadn't noticed before. When I shift back to drive, I think it's a single click.
Is this normal? I thought I'd better ask. Thanks.
Old Mar 7, 2006 | 03:45 PM
army2000's Avatar
army2000
St. Jude Donor '11
Is this normal? I assume so, but thought I'd ask. Thanks.
Not normal. Get it checked out yesterday.
Old Mar 7, 2006 | 03:53 PM
JMc's Avatar
JMc
Aw crap. You're kidding, right?
Old Mar 7, 2006 | 04:02 PM
Ghost Vette's Avatar
Ghost Vette
Don't have that sound here. Have it looked into.
Old Mar 7, 2006 | 04:05 PM
JMc's Avatar
JMc
Hmmm. I just noticed it this morning for the first time. If it does it again, I'll make an appointment and bring it in. All I can say is, thank goodness the PO bought the extended GMPP with zero deductible that I was able to assume!!!!
The poor guys at the dealership really hate to see me coming!
Old Mar 7, 2006 | 04:09 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Definitely not normal. Take army2000's advice and get it looked at pronto.
Old Mar 7, 2006 | 05:12 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Not normal, mine is so tight I can not tell if the car already engaged the gear yet
Old Mar 7, 2006 | 05:14 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Mine does the same thing. Never could find out the problem. Seems to be coming from the drivers side. I do have aftermarket lug nuts but they're torqued properly so I don't know. Its been doing it for awhile with no serious problems.
Old Mar 7, 2006 | 05:24 PM
JMc's Avatar
JMc
Feh... Although misery loves company, I think I'll take a drive over to my local dealer and ask the service tech's opionion this afternoon. Shouldn't take too long to get his thoughts, at least.
Thanks for the input, gents.
Old Mar 7, 2006 | 05:26 PM
TEXASCOUPE's Avatar
TEXASCOUPE
Let us know what you find out.
Old Mar 7, 2006 | 05:27 PM
JMc's Avatar
JMc
Will do.
Old Mar 7, 2006 | 05:28 PM
Rhode Warrior's Avatar
Rhode Warrior
I don't have that either.
Old Mar 7, 2006 | 05:48 PM
BiggieBoy's Avatar
BiggieBoy
Agree w/ all the others---not normal
Old Mar 7, 2006 | 07:44 PM
JMc's Avatar
JMc
I determined that it only makes the clicking noises when shifting between Drive and Reverse and vice versa. So I drove over to the dealership this afternoon, unannounced and asked my service adviser to take a listen and see what he thought. He went into the shop to ask the transmission guys, but they were tied up with what they were working on and asked me to bring it back anytime late in the morning this week when they can give it a listen and determine whether it's within normal parameters or the transmission needs to be opened up. They said it could go either way. So, the saga continues. I'll post again once I get a diagnosis. I plan to drive it back over tomorrow morning and see what they think. Other than this weird click-settling sound going on, the transmission feels very tight. Shifts are crisp. No other issues. I'll report back tomorrow.
Old Mar 7, 2006 | 07:56 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
It's normal. Read your owner's manual
Old Mar 7, 2006 | 07:57 PM
eitspc5's Avatar
eitspc5
JMc,
I also had (have) this issue. I have had the rear right wheel hub replaced by the dealer, they said it had worn and was slipping...I also have had the diff serviced, refilled twice. The problem was gone and came back shortly after each fix. I am getting a new diff installed this weekend, and I am hoping that this issue will go away as an added bonus to the install. I will let you know, looking forward to hearing what your fix is as well.
Rick
Old Mar 7, 2006 | 09:14 PM
austin683's Avatar
austin683
Without actually hearing the noise it's hard to say. Of course the transmission makes a "click" when switching to reverse but you described a series of clicking. Because of this I would agree with all the above and say it can't hurt to have it looked at.
To Question for A4 guys
Old Mar 7, 2006 | 09:15 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old Mar 7, 2006 | 09:20 PM
JMc's Avatar
JMc
Originally Posted by eitspc5
JMc,
Rick
Wow. All under warranty?
Old Mar 7, 2006 | 09:32 PM
troy144's Avatar
troy144
