The Grond Chronicles : More Mods (are you taking notes?) [Dialup Anguish]
Supporting Tuner
Originally Posted by GOZ2FST
Gee - lot of banter here.
Anyone besides me without a clue as to what those two gizmos do for you?
http://forums.corvetteforum.com/show...52&postcount=1
Location: Greensboro, NC "REALITY IS MERELY AN ILLUSION, ALBEIT A VERY PERSISTENT ONE"...ALBERT EINSTEIN"
St. Jude Donor '05-'06-'07
Keep the mods comming, and thanks for sharing your passion for your Vette with us
Always a good read, and sometimes some "lively banter"
Gee, I thought I was in the OT Forum there for a minute. Didn't know the Brits had a Vette Forum. I'l have to give it a go.
MONARTOR
housecleaning done....
#33
Supporting Tuner
: UPDATE :
Installed the TracActive Controller and discovered a nasty surprise!! The former owner had an alarm installed and whoever installed it butchered the wiring!!! One of the many reasons I do not allow anyone else to work on Grond.
All fixed now and the Laptrax TracActive Controller Deluxe is installed and fully functional.
Here are the pics and this is the end of this particular mod. I will post the Kenne Bell Boost-a-Pump mod in a seperate thread.
All so they could install 2 resistors - what idiots!
#34
Supporting Tuner
The Brown wire from the Laptrax connects to the Brown/White wire from the BCM
Accessory Power connectors - yellow connects to yellow switched power and black connects to ground. Just three wires and you are done!
#35
Supporting Tuner
Laptrax tucked in and good to go
Fire it up - works like a champ
#36
Supporting Tuner
Video of the LapTrax TracActive Controller in action
5mb MPEG4 Need QuickTime 7 or VLC VideoLAN ( www.videolan.org ) to view
#38
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Originally Posted by EnglandGreen
: UPDATE :
Installed the TrackActive Controller and discovered a nasty surprise!! The former owner had an alarm installed and whoever installed it butchered the wiring!!! One of the many reasons I do not allow anyone else to work on Grond.
All fixed now and theLaptrax TrackActive Controller is installed and fully functional.
#39
Supporting Tuner
No, that is a TSB. I found the new blower controller under the glove compartment.
