List of owners with EBCM ISSUE ?? ??
Cruise-In V Veteran
St. Jude's Donor '05
Talked to dealship today. Big Props to Bob Wrinkle at Classic Chevrolet in Grapevine, Tx. There gonna cover it under warranty
Here are the current members with EBCM issues and their status (please update if incorrect)
Repaired under Goodwill Policy
dmcantrell - 2003 vert - covered under goodwill policy
rikhek - 2004 Z06 - covered under goodwill policy
Purchased Part
jrc27 - 1998 - purchased part #9367071 EBCM for $277
Bret01Z06 - 2001 - 52k - $200 off a repo
brokebyducati - 2000 - EBCM AND BPMV paid out of own pocket $$$$
Lancer033 - 2002 - purchased new EBCM for $650
CHRP 1 - 2002 Z06 - 1/2 covered but cost $1200 of a total $2,984.00 repair EBCM and also brake pressure modulator valve
Replaced Under Warranty
CalHusker - 2001 - Replaced under GMPP warranty
roscoe118 - 2002 - Replaced under warranty
jedicowboy - 1998 - Replaced under 3rd party warranty 75K
Glennm27 - 2002 - replaced under GMPP
KonaVette-1998-EBCM from Fichtner Chevrolet $340.49 DIDN'T SOLVE THE PROBLEM.... IT WAS THE GROUND WIRES.
Unsure of status of repair
Rob'sC5 - 2003
ThePatriot - 2001
chiefDave - 2001 Z06
Bill Curlee - 02 Z06
TexasAg28 - 2001 - ??
C5_pewter_vette - ??
c502 - 2002 - ??
camaro_zach - ??
4DRUSH - 1997
Please copy and paste, and update with your info...
thanks
Purchased Part
Rob'sC5 - 2003
ThePatriot - 2001
c502 - 2002 - ??
camaro_zach - ??
4DRUSH - 1997
thanks
I think this is a good post. This should help us fix our problem.
Plkeegan And trussme stated in my post that they replaced their battery and the codes went away
Had mine fixed under GMPP Warranty about a year ago on my 02 Z with 13k miles. Only 4 weeks after i bought the car used from a Private Party. I did my first burn out in it, and the DIC lit up like a X-mas tree! It said," Check Active Handling, Check ABS, Check Traction Control." i was freakin'!!! Good thing i bought that warranty. 1 month in and it paid for itself.
I believe both those members had intermittent ABS/Traction codes being set. Where as mine are constant and cannot be reset (when you reset the code it instantly pops back up again) I believe this is a tell tale sign that its the EBCM and not something inter-related.
ebcm
Total cost of bill was reduced to $2,400.00,GM covered half of the cost.My part of the cost was $1,200.00.Dealership said it was covered under the Good Will Policy. thru GM.
#33
Originally Posted by nuch
EBCM is responsible traction control/abs/stability control, do a quick search for EBCM, and you will learn lots.
This is just great - another impending failure added to the growing list: Column lock, fuel gauge, hazard switch, oil pressure sender, rocking seats, headlight gears, door lock & window modules....
What have I gotten myself into here? GM's flagship.... right?
#35
Originally Posted by Lancer033
Purchased Part
add me in, jrc27 where did you get one for $277? Was it used?
#37
Purchased Part
CHRP 1 - 2001 Z06 - 1/2 covered but cost $1200 of a total $2,984.00 repair EBCM and also brake pressure modulator valve
FILMELF - 2004 - replaced at dealership at own expense
Rob'sC5 - 2003
ThePatriot - 2001
c502 - 2002 - ??
camaro_zach - ??
4DRUSH - 1997
nprsuit - 00 with 26K -??
dh305 - 00 with 28k -??
thanks
nuch
View Public Profile
Send a private message to nuch
Send email to nuch
Find More Posts by nuch
Add nuch to Your Buddy List
Add nuch to Your Ignore List
Page 2 of 2 < 1 2
Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 General
Purchased Part
Rob'sC5 - 2003
ThePatriot - 2001
c502 - 2002 - ??
camaro_zach - ??
4DRUSH - 1997
thanks
nuch
View Public Profile
Send email to nuch
Page 2 of 2 < 1 2
#38
Active handling began problems at 75k miles. dealer was unable to locate problem. Going 60 mph on straight freeway with active handling suddenly engaging brakes caused me to get rid of 2001 Vette at 86k miles.
This was the worse Vette I ever owned. Way too many problems and poor GM attitude
#40
I have had trouble codes popping up randomly - may lead to an EBCM issue - but for now, she has been OK for the last month (could have just been connectors)
BTW - what is goodwill policy?
