Brake Screeching
Old May 30, 2006 | 10:44 AM
rwsr50's Avatar
rwsr50
Default Brake Screeching
Does an 04 have the wear sensors on the brake pads that make the screeching noise when the linings get too thin? I thought all cars had them, but was surprised my Audi A6 has no kind of warning system.
I'm getting a high pitched screeching sound sometimes when I brake. I'm just talking normal braking from around town speeds. The car only has 17,000 miles on it so I wouldn't think the pads would be worn out already. Could it be just the type linings I have are noisey? I assume they are the OEM ones. I just got the car in Jan. with 13,000 on the clock.
Old May 30, 2006 | 10:59 AM
KidCid's Avatar
KidCid
CI 7-8 Veteran
The sound you hear is most likely from a glaze that has built up on the pad. I don't see any info in your profile about your car but I'm guessing it's and A4. People with A4s tend to brake more because they don't downshift when slowing down and have the engine gobble up some of the speed.
There was a post here several month back about doing some spirited stops to burn off that glaze. I'm not sure how effective that may be. I'm thinking that slotted rotors would help freshen the pad and keep the glaze from forming. This will cause decreased pad life though.
Old May 30, 2006 | 11:21 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
Answer to question 1: yes, the inner pad has a metallic tang or "sensor" that rubs against the rotors when the pad is low. At 17K miles, it's unlikely the pads are worn yet, but I have seen some heavy-footed drivers in my mechanical career. It is possible to have glazed the pads like Kid said. If you do change rotors, you should take a sanding block with some 400 grit sandpaper and sand down the glaze off the pads. Then you should lay on a layer of synthetic caliper grease on all metal-to-metal contacts(ears of pads and back of pads). That should help out future squeals, good luck!
Old May 30, 2006 | 12:01 PM
rwsr50's Avatar
rwsr50
Nope, it's an MN6. I don't downshift that much when I know I'm going to be coming to a complete stop though, like at a stop sign or red light. I figure why put that wear and tear on the clutch. I figure it's a lot cheaper and easier to replace brake pads than a clutch. Thanks for the reply.
To Brake Screeching
