Turn Signal Issue
Old Jun 10, 2006 | 08:55 AM
indy300's Avatar
indy300
Default Turn Signal Issue
Has anyone else had this problem or have a suggestion for a cure?
This has happened three times now in the past year. My turn signals stop working for several minutes. I flipped the turn signal lever several times and...nothing. Then all of a sudden they start working again.
Thats weird.
thanks in advance.
Old Jun 10, 2006 | 09:00 AM
JeepTJ's Avatar
JeepTJ
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Common problem with our C5s. The hazard light switch has gone bad. Next time it happens, push the hazard switch a few times. If that fixes the problem, then time for a new switch.
Good Luck
Old Jun 10, 2006 | 09:12 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Or...there's a partly broken wire in the switch's wiring harness that runs down through the steering column. These wires get bent every time you adjust the tilt wheel. Try moving the column up and down a few times and see if the problem corrects itself.
Tom
Old Jun 10, 2006 | 09:31 AM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
Good Luck
Old Jun 10, 2006 | 09:38 AM
lightning30's Avatar
lightning30
never had any problem like that with mine.
Old Jun 10, 2006 | 09:51 AM
Frozenfire's Avatar
Frozenfire
That happened to me a few weeks ago. Now I know what to look for/try. Thanks!
Old Jun 10, 2006 | 10:09 AM
muncie21's Avatar
muncie21
It will only get worse...fix it. It takes about 30 minutes to replace the relay and the relay costs about $25.
Old Jun 10, 2006 | 10:21 AM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
Good Luck
Same thing happened to me right after I bought my C5... GMPP warranty covered it, otherwise I would have fixed it myself.
Old Jun 10, 2006 | 12:13 PM
indy300's Avatar
indy300
thanks for the suggestions guys. Where is this relay located?
Old Jun 10, 2006 | 01:00 PM
muncie21's Avatar
muncie21
Behind the hazzard switch in the center of the dash.
Old Jun 10, 2006 | 01:34 PM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
Good Luck
I've done this for about 3yrs., lasts about a month, then push it a few times, good to go.
To Turn Signal Issue
