The Grond Chronicles : Reincarnation Part 4 [Dialup; Agony & Ecstasy]
#402
Supporting Tuner
UPDATE
Received the 12 foot shift cable from Jegs and installed it today. The default cable is 5 feet long and it was way too short. Also began the shifter install process and the first tentative steps of 2 other custom installs. The B&M Pro Ratchet shifter is a FIRST in any 4L60E C5, BTW
Here are the pics
12 foot B&M cable installed.
OK. Onto the shifter install. It's going to be tricky but I'll get there
Stock shifter in the foreground, B&M Pro Ratchet shifter in the background
Let's get the stereo and climate control bracket out of the way
Offer up the stock for reference
Stock stripped - and reference points marked
If I just bolted the ratchet shifter here - it would be way too high and seriously ugly
Here are the pics
#403
Supporting Tuner
So that calls for a different approach
Hurm - looks good. Me likey
Mark out the area
And cut it out. I LOVE MY DREMEL !!!
That's a little better
But it needs more cutting
Mark out the area
#404
Supporting Tuner
Not a bad fit - but still not right
Back to the Dremel
That's the ticket!!
On the money. This is going to be sweet
Don't try this at home, kids
Back to the Dremel
That's the ticket!!
#405
Supporting Tuner
I have a lot of welding to do to finish the shifter mount, so I will revist that in a bit.
And so onto the next mod
Time to do something about this...
My trusty Dremel to rescue one again
Stock bracket (minus the lightly modded backtab)
Let's start by removing the top stereo standouts
And that now useless lower bracket
Offer up the repositioned climate control
#406
Supporting Tuner
And if you were ever curious to know what was behind your center console - here it is
Oh yes, and a trial fit of my next mod...
#410
Supporting Tuner
Originally Posted by Frizzle86
so what do u plan on cooling back there? Thats not for the trans is it?
#411
Successful Plumber
Location: Top of the hill, 3rd mailbox on the right. Texas
CF NCM Ambassador
CI 6-7-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
NCM Member '09
I love the weekend because it's when the new EG mod photos arrive online. I think I've deciphered some of the code -
Getting
Radical with
Our
Nuclear
Dremel.
Getting
Radical with
Our
Nuclear
Dremel.
#412
Supporting Tuner
Getting
Radical with
Our
Nuclear
Dremel.
Getting
Radical with
Our
Nuclear
Dremel.
#414
Originally Posted by EnglandGreen
Dual transmission coolers. The radiator cooler lines have already been removed
So how are you thinking about getting air-flow to them? Tap on the cabin air?
#415
I don't think I could EVER put any of that stuff back together again, even if I were the one to remove it all. You are a brave(and insane) individual EG.
#417
I've been away a while playing with my other toys (gf included..heh heh)
I can see my old friend EG here has thoroughly lost his mind lol
#418
I would think its possible to have air deflect up the underside of the rear bumper fascia.
But thats just a hunch.
#420
Supporting Tuner
