The Grond Chronicles : Reincarnation Part 4 [Dialup; Agony & Ecstasy]
#442
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Originally Posted by Z06ufgrad2002
Won't this need to slide back farther for the seats to fit?????????
Yes, bars were left long in a couple of places since he is doing a self install. And, since the cage was shipped practically whole, just wanted to make sure there were no errors on my part.
Also shipped him some practice pieces.
#443
Supporting Tuner
I'll need them too
#444
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
#445
Ok, I know, try to keep up...
But I have a question, teacher.
That is a B&M shifter? Is the installation that radical as a matter of course or because you're adapting another model or because you want it to mount differently or...?
#446
Supporting Tuner
B&M themselves said it will not work with a 4L60E unless you buy an "aftermarket transmission computer". I explained that it's a Vette - I already have a PCM - but they insisted that it would not work. Hurst said the same thing, so did TCI. I tried the racing sites - Jegs, Summit Racing, MrRays... same answer - "it will not work with a 4L60E"
So, we will see if it will work or not - and I had to mount it so it looks stock - that's the whole point
#448
4L60E being the stock A4 or an upgraded item? I've lost track, it's a wonder you haven't too.
What about upgrading to the A6 with the paddle shifters? Could that be done?
#449
Supporting Tuner
The 6L80E - the 6 speed "paddle shifter" transmission from the 2006 C6, has been successfully retrofitted into a C5 by Yank. It costs $10,000+, and comes with a custom torque tube, wiring and computer. Oh yes, and you need a new differential as well. That cost does NOT include the paddle shifter, BTW - or gears.
#452
for 10K you could get a twin turbos and with ur race trans from RPM shift faster then the paddle shifter (possibly the stock A4 trans shifts faster anyways).
Best get lots of welding practice in. I want to see those welds look like a roll of dimes on its side.
#453
It is always fun watching these.
I know you are doing a wheel project. Have you released any details? Did I read earlier about some crazy wide wheel? Are you sticking with the C5 coupe style wheel.. but only wider? Just making sure I didn't miss any unveilings.
#455
4L60E is the stock "A4" - automatic in C5s. I have a (RPM) Rodney built A4 set up for full race but without the manual valve body.
#456
#457
Supporting Tuner
#458
Details have not been released. That one will be a pretty radical surprise
With NEON!!!
This build is awesome. I can not wait see it finished.
Sui
#459
These threads need to be rated "R" for us garage queens!
I'm going back to the "PG" section, my eyes can't take much more of this
#460
Supporting Tuner
UPDATE
Started working on the rollcage final fit. Tomorrow - I weld
Here are the pics
Any excuse to buy even more tools
Needed to remove about 8.5 inches all told
Action shot
Measure trice, cut once. I made 3 passes to get the length just perfect
[Austin Powers voice] Yeah baby!! [/Austin Powers voice]
Here are the pics
Action shot
