The Grond Chronicles : Reincarnation Part 4 [Dialup; Agony & Ecstasy]
#43
Supporting Tuner
Originally Posted by Ikester
Job well done.But why would it be ecstasy for dial up users? if it is then im going dial up!
#44
St. Jude Donor '06
Good stuff EG... as usual...
Fiberglass dust sucks!!! Itchy-itchy-itchy!! Have someone hold a vacuum nearby to suck some of it up as you go helps but you may plug a filter quickly..??? (Not a Craftsmen though!) An idea you likely thought about already but if not...
Wash with cool water and then lotion your self where you were exposed to keep the itching to a minimum... Cool water keeps your pores closed and lotion helps relieve the irritation... Again, more stuff you likely knew but just in case...
I hate itchy fiberglass!!!
#45
You Cut your car - Are you Freekin' nutz???:a
I'm looking forward to what you are doing, and what step 5 is, and I'm reminded how nervous I was when I swapped my T/C and rear carrier this winter - my mods then were tame compared to what you are doing. You got BIG kahuna's to do that!
#49
Stephen...how do you propose to work around the pads for the coupe top? [I guess that is the biggest difference between an FRC and a Coupe!...beside speakers]
#50
Damn stephen i had no idea that you were going to get this serious with the car! I cant wait until its finished! I'll be in town from the 4th-10th so if you need some help then let me know and ill be more then happy to make the short trip down and help out!
#56
Dam EG, your much braver then I am, keep up the good work and i'll keep watching, i may learn something but still wouldn't dare to do half of what you do
#59
Supporting Tuner
Originally Posted by Zilla
EG look great so far what size tires 345's?
335/30ZR18 Rear
275/35ZR18 Front
I have 275's on the front right now and love it. The compound of the tyre is more important then the overall width (for me). We will see how it goes.
#60
Supporting Tuner
Originally Posted by connecticut
where is the new rolling stock? would this void my warranty?
