I had heard the mechanics at GM dealerships do not like to work on Corvettes because they are compact and tough to work on. Since the mechanic gets paid a flat rate per task they can not make as much money on vettes as they can on other models. As a result the more experienced ( and better ? ) mechanics will pass on vettes and let the newbees in the shop have the pleasure.
I had also heard that some shops charge vette customers 1 1/2 times the normal hourly rate to enable them to give something more to the mechanic.
Some dealerships may do that, but the one I go to does not. If you find a shop that operates like that, maybe best if you look for another one.
The shop I use has a couple of guys who can do basic oil changes, but for other work has a "Corvette guy." Recommend you go to your local club or the CF regional forum for a recommendation on who to/not to use.
Chevy dealerships are required to have a certified Corvette mechanic in their dept. Not all chevy mechanics are allowed to work on them.
A dealer can't just assign anyone to work on these cars since they are significantly different than other GM cars, i.e. multiple control computers, sensors, drive by wire throttle, etc.
If a dealer wanted to play the game of using "rookie" mechanics, it will definitely end up costing them more because the chances of doing the job right the first time is low.
. despite opinions of most, my dealer's service department has been great. I've actually had mod's done from print outs from CF, like lowering, and I mean low! The cost of having a dealer do the work is off set by the assurance that,they have a lot to lose, should you not be happy. The local guy just looks cheaper. It's perception. If your dealer is a hack, that's too bad, move on or write GM.
Corvette owners are considered a pain in the *** by most service departments. We are fussy. Find one that understands the nature of someone who is "keeping" his/her car, as apposed to the 80% that lease. There is the problem.
but I digress
Any confirmation or opinions on the above?
Thanks in advance.
When you are buying the car it's all promises. Then reality sets in.
I haven't heard this before. I know my dealership always keeps at least 2 certified Corvette mechanics onboard and they are the only ones allowed to work on Corvettes. If your dealer's shop operates using those type practices, then I too would say its time to fine another shop.
