BCM programming year specific??
Old Aug 23, 2006 | 06:42 PM
Motorhead5673's Avatar
Motorhead5673
Default BCM programming year specific??
Has anyone successfully reprogrammed a BCM from a different year C5 than the car it is installed in? Such as a 98 BCM in a 99 car. I'm rebuilding a 99 theft recovery and part of the repair was to replace the BCM. I purchased a used BCM that allowed to car to start (after the learn process) but showed a "Service Column Lock" fault that will not clear. However, I think it has more to do with the VATS than the column lock. When I took it to the dealer for programming, they said the 98 BCM I had could not be programmed for a 99 in order to clear the column lock fault. So the question is do I need a 99 BCM or simply a key (resistor) to match the code stored in the 98 BCM.
