[Z06] Is the 2004 Z06 PCV Setup Different?
I keep hearing that the PCV system was changed for 2004 on the LS6 ... and LS1 ??? ... to this setup.
I know the LS2 and LS7 engines uses no external PCV valve, but use a fixed 2.5 mm diameter orifice built into the valley cover hose fitting to regulate the engine's vapor flow to the intake manifold.
Can anyone post a pic or verify the 2004 LS1 and LS6 PCV system setup?
Thanks!
