ok so i was on the highway about 100 miles from home and i got a service active handling an traction control warning then it goes into reduced power mode.I drive home slowly and call the dealer ,get an appointment the next day and when i started it it was fine the dealer says no codes stored .i bring it home and a few days later go out to the garage to start it same problem back to the dealer ,this time theres a code for the throttle pos.sensor which they say the tested and its fine.....i bring the car home and go to start the next day same warning and reduced power again ...... any ideas thanks
my car does that once in a while when i punch it all the way i just reset the codes when it happends.....turn the key on ....hold opt. and press fuel 4 times....all the codes will come up....hold reset on any codes
rarely but after hitting a large bump they light up . 2 things ya can do if while driving just turn the key to start that resets it . one night 4or5 times second scan it mine was 1or2 wheel sensors just unplug them and push back together [not while driving]
Huh? That would be a neat trick to unplug your sensors while driving
Every once in a while you can get a glitch like this. If this occurs right after hitting a pot hole, or a hard bump. simply pull to the side of the road. turn the ignition off, then restart the car. The warning should go away if it was a ghost... ( not a real fault, but a glitch. )
Bill aka ET
