Horse Power
You might consider a set of high-ratio rocker arms. I think that with springs those run $8-900, and figure another couple hundred for install. 10-15 rwhp. But they don't work well with big cams so it's money down the drain if you buy a big cam later.
Part of the problem is that unless you do a fairly good-sized step, you'll never feel it. You can't feel 10 hp (imo).
I do agree that a set of gears would give a lot of bang for the buck in your situation. You would definitely feel that if you went up 10% or more.
If you can do your own labor then these numbers change quite a bit.
Most guys do this stuff in two to four "blocks": first is headers and CAI, no tune yet, $1500-2500 installed. Next is cam, $2500-3000 installed and tuned. Next is heads, $1700-3000 installed and re-tuned, and finally some go for the "frills" like a FAST 90/90 intake ($1500+), electric water pump ($500), etc.
Now you see how complete packages at major tuners start at about $10,500 and go up from there. Yeah, I wish it was cheaper too.
And a 100 shot!
