Why is my C5 slow?
Old 01-05-2007, 04:24 PM
  #41
verskel
verskel's Avatar
Just curious but what tranny do you have - an auto ?
Used to own a '98 coupe A4 and I could get more out of it by manual shift right at the redline.
Otherwise, if you have a 6-spd and your clutch is slipping then the run times will suffer.
Old 01-05-2007, 04:40 PM
  #42
photoguy
photoguy's Avatar
Get a tune up and try again!
Old 01-05-2007, 06:54 PM
  #43
Burgie
Burgie's Avatar
Originally Posted by NJ Vette Guy
Everyone is quick to blame the car......
But by what he posted (left the car in OD and left traction control on), I seriously doubt he even knows how to properly launch an A4.
If I were him, I would do a forum search on the proper launch technique.
Just for quick reference though, next time you go to the track:
1. Place the car in competition mode (you'll be happy you did).
2. Put the car in 3rd gear.... Let it do the shifting for you.
3. Put your left foot on the brake and hold the gas pedal down until the tachometer is holding around 1500 RPMs. If the wheels are slipping, then back off a little on the gas.... If they're not, then appliy a little more gas until just before the wheels spin.... DON'T SMOKE THE TIRES!!!
4. When the last yellow light lites, let off the brake and at the same time, push down the gas pedal..... Don't stomp it, but firmly press it all the way down. If you do it right, you won't "red light".
5. Hold on and pay attention to the road and the car, don't look at the other guy or the speedometer..... As you pass the finish line let off the gas and slowly apply the brakes, don't slam them on.
If you do that, I bet your track times will improve..... If not, then check out the car.
Good luck.......
Tried that with a 98 auto-no go, engine falls flat. If you turn off the traction control only you can power brake and get the response you want but not in Competition Mode- Been told that is a design flaw for 98s
Old 01-05-2007, 07:32 PM
  #44
2K14C7
Support Corvetteforum!
2K14C7's Avatar
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
New air filter and plugs is a good start. I would also have the catalytic converters checked to see if they could be going bad and possiblly clogged.
Old 01-05-2007, 07:38 PM
  #45
Vette Dream
Vette Dream's Avatar
There's definitely something wrong, and no matter how poor your driving, you 91mph trap speed is way too low. It's about 15mph slower than it should be. You track results are equivalent to a 200hp V6 Camaro.
I don't know how mechanically inclined you are, but I would agree that taking your car to an experienced, Corvette mechanic/specialist. Prior to that, the one simple thing you can do is check to see how dirty/clogged your air filter is, because if it's limiting airflow to the engine, it can affect power output.
Old 01-05-2007, 07:44 PM
  #46
CHASLS2
CHASLS2's Avatar
St. Jude Donor '13
Maybe the doc drove the car like a snail for all them years, and the computer is trained to his snail like driving.
Old 01-05-2007, 07:52 PM
  #47
Ettev01
Ettev01's Avatar
Just a thought! Was it a California car? Maybe the Cat converters are clogged? Seems like every California car I've seen goes through Cats. early.
Old 02-20-2007, 09:11 PM
  #48
Ryan L
Ryan L's Avatar
Troll.
Just like every other thread you started. *yawn*
Old 02-20-2007, 09:16 PM
  #49
MTLNY
MTLNY's Avatar
Try tking your foot off the brake...if that doesn't work check the washer fluid, it might nedd topping off...
Old 02-20-2007, 09:57 PM
  #50
superjet701k
superjet701k's Avatar
Default Slow
PULL IN THE ANCHOR
Old 02-20-2007, 10:22 PM
  #51
oldschoolvette
oldschoolvette's Avatar
Originally Posted by ZeeOhhSixx
Holy crap! did the car always feel this slow? When did it feel like it lost power.
Old 02-20-2007, 10:37 PM
  #52
DefenderC5
DefenderC5's Avatar
Originally Posted by Ryan L
Troll.
Just looked at his other threads too.
I thought he may be racing at 6000 ft altitude or something
Old 02-20-2007, 11:05 PM
  #53
RED99
RED99's Avatar
Let someone else that has experience in the 1/4 mile drive your car and see if they get close to the same ET. That will tell you if it's the driver or the car. If it's the car, then I would go do a Dyno pull and have them scan it while doing a pull. There is about a million things that can cause you to lose power.
Old 02-20-2007, 11:13 PM
  #54
Frizzle86
Frizzle86's Avatar
oh i wish i was at the track when u were racin a 15.1 sec C5. i can see some kid with a turbo honda runnin 14's thinkin he just smoked a c5
Old 02-20-2007, 11:15 PM
  #55
rc69wc
rc69wc's Avatar
Originally Posted by jah
I will turn the traction control off next time (I can't believe I didn't think of that there!). Could this make that big of a difference?
What else can I check? Fuel/Air filters? Should I have a shop check it out? Will a diagnostic test tell me anything or do they have to do a dyno on it? About how much is that (incl. vette tax!)?
hold the traction control button down until cmpetitive driving mode pops up on the dash for some reason its a hidden feature
Old 02-21-2007, 12:56 AM
  #56
myk7
myk7's Avatar
Clean your MAF
Old 02-21-2007, 01:31 AM
  #57
MUKAK
MUKAK's Avatar
Troll.
this guy dont make sense..... he starts treads just to attract attention....
Quick Reply: Why is my C5 slow?
