LS7 Clutches Available!
Old Jan 21, 2007 | 12:53 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
Default LS7 Clutches Available!
Hi All,
The LS7 clutch kits are available. To get final prices shipped and order go to the website at www.gmpartshouse.com. Click where it says click here to enter part number search. Use the following part numbers under Chevrolet make.
LS7 clutch, pressure plate and flywheel - PN ls7clutchkit - 398.05
If you need C6 master or slave cylinders contact me....
04 Z06 slave cylinder - 89059282 - 105.95
04 Z06 master cylinder - 12564455 - 108.06
Pilot bearing - 14061685 - 9.79
If you want to new flywheel bolts - 12553332 x 6
If you want new pressure plate bolts - 12561465 x 6
Thanks!
Gene
