I want to drain the coolant in my 1999 coupe. If I just drain the radiator, what % of the total fluid will I change out? I've heard power flushes are not a good idea. Any thoughts?
Geez, with that title my mind was racing. He wants to drain his what? Bank account? Swimming pool? Lizard?
Ah, just a radiator. I see.
Well, why just do that? Let's say you get out half (approximate, don't have my manuals here.) Why stop there? You already have to get a little messy and dispose of the waste. Why not just fill it back up with water, run until the thermostat opens, drain again, repeat till clear. Then put in the required amount of coolant, and top off with water. (Distilled, tap, Evian, whatever you prefer.) And you're done!
I sure am not smart enough to know what % will be left in the engine but I know it is not rocket science to flush and fill antifreeze.
I would drain the radiator. Fill with water and run the car with the heater on high until the thermostat opens. Do this several times. If you pull the thermostat (two bolts) you can run water from the garden hose though the engine too. Pulling the hoses from the water pump and flushing those helps too.
Just takes time, especially if you are waiting for the thermostat to open and a lot of water but it is not difficult and I highly recommend it be done every couple of years. Very little cost to prevent scale, rust and corrosion.
I drained out all but 2 quarts of mine. Keep car level after opening drain plug. Shop manual says no need to flush if it is clean. Mine was, I did not flush.
Do use distilled water. Fill at least 3 times, reving it up to 3,000 rpms and waiting until it reaches 190 degrees. This gets air out.
With dexcool, once every 5 years or 150,000 miles is okay (Really).
Hard to have any bank account when owning a Corvette. And, as for draining the pool, that's easy........just tip it over!
I think I'll run the engine as you described to remove even more of the old product. I've got a '99 with 30K on the clock. Even though it looks O.K., it's time.
are there drain ***** on the lower walls of the block? on the sbc's we would pull the plugs in the lower block and drain both sides of the block. or we would pull one of the heater hoses and force water through there. but i see that both heater hoses on the ls motor are in the t-stat housing. is there a divider inside the housing to direct the water flow through the block?
I think just draining the radiator gets you about 2 gallons, which leaves 1 gallon in the block. The total capacity is about 12 quarts.
If you flush until you have just water left in the block, you would need to add 6 quarts to the radiator, then finish with distilled water for a 50/50 mixture.
