Battery keeps draining
Old Mar 19, 2007 | 10:04 PM
MilleniumVette's Avatar
MilleniumVette
2024 C5 of the Year Finalist - Unmodified
Default Battery keeps draining
Every couple of days my battery keeps losing it's charge. It began doing this with the last battery (hence, why I bought another one) if I listened to the radio for about a 1/2-hour without the car running. It's now gotten worse, and is losing charge just sitting in the carport.
So, my question is, is there one more common area than others to look at for draining my battery while it's off? Maybe something typical that other owners have experienced?
Any help would be appreciated. Thanks in advance!
Old Mar 19, 2007 | 10:21 PM
11yellowgscpe's Avatar
11yellowgscpe
The batteries in these cars seem to train easy. Go to Harbor Freight and buy a Battery Float Charger. It will keep your battery charged and will not overcharge. It also will not charge a dead battery. I paid $7.00 for mine.
Old Mar 19, 2007 | 10:28 PM
MilleniumVette
That will definitely be something I'll check into, but this is more serious than a regular drain issue. It's been something that is getting worse. To the point I wouldn't take the car too far from home and consider it reliable for a re-start somewhere.
Old Mar 19, 2007 | 10:59 PM
rrichar2591's Avatar
rrichar2591
Not sure how long you've had the battery but if it were mine I would take to some place and have it tested under a load. I had to do that with mine and it showed a weak cell. Battery was still under waranty so was replaced with no cost. At the same time they are testing battery they can usually test rest of charging system to see if there is a current draw etc. Most places will do this for free such as Sears, Autozone, etc. My chevy dealer did mine because I still had the orig warranty on the AC Delco. Good luck.
Old Mar 19, 2007 | 11:08 PM
C5naples's Avatar
C5naples
I had a similar problem. The mechanic that works on my car only works on vettes. The first place he looked was the visor mirror lights, he checked to see if they stayed on when closed. He also said that water will sometime leak into the switches on the electric seats causing them to short and drain the battery. My car does not get driven enough because of my work schedule. I sometimes put the float charger on it and it has been good ever since.
Old Mar 19, 2007 | 11:38 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
How old is your battery? It might have lost its ability to hold a charge. May be time for a new one.
Old Mar 20, 2007 | 12:18 AM
az57chevy's Avatar
az57chevy
Do you have a stock radio or after-market?
Old Mar 20, 2007 | 02:27 AM
DeeGee's Avatar
DeeGee
I see you have a 2000. If its the original AC Delco battery change it now as a precaution. Those batteries are prone to leaking and the results are catastrophic. The PCM is under the battery tray and any leaks damage the wiring and computer. Seven years is good for any battery and $150 for a new one is a good insurance policy.
If the battery is on its way out a new one will probably solve the problem.
Optima offer a 3 year guarantee. If it loses its charge after you fit it they'll replace it for free.
You could also try a battery drain check. Bill Curlee posted a great "How To":
http://forums.corvetteforum.com/show...rent+draw+test
Old Mar 20, 2007 | 10:29 PM
MilleniumVette
Thanks gang. You've given me some ideas where to look first. Nothing worse than thinking you got an expensive paper-weight in the drive.
It's a newer battery. Probably getting near a year old right now. It totally went over my head to have the battery tested right off the bat, though. I was probably too ticked off to logically think things out.
Old Mar 20, 2007 | 10:31 PM
BATM4N's Avatar
BATM4N
Mine had the same problem and was 5 years old and was supposed to last 7 years
Old Mar 21, 2007 | 01:50 AM
Herringchoker's Avatar
Herringchoker
From: "Man been singin' the Blues, since he began to till the ground"...Vancouver, USA WA.
Visor lites, under hood lite.
Old Mar 21, 2007 | 02:10 AM
DeeGee's Avatar
DeeGee
The other gotcha is the cabin lights. Theres a rotary **** on the front panel to the left of the steering wheel. Its possible to have that cracked open (turned clockwise) and for the lights to be on.
Not sure if thats tied into the power saver circuit. They may go out after 15 mins or so like the other lights.
I found that by accident when I closed the car down in a dark garage and all the interior lights were still on.
The drain check should tell you whats causing the problem.
Old Mar 21, 2007 | 03:42 AM
rc69wc's Avatar
rc69wc
also try cleaning all of the ground plugs i think there is 10 or more they are easy to find just look for grey plugs on the frame,they are easily corroted some how my car is only 3 yrs old and they were dirty as helll
Old Mar 21, 2007 | 03:49 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
To Battery keeps draining
