33 MM Socket
Old Jul 1, 2007 | 04:33 PM
ROJ#79's Avatar
ROJ#79
Default 33 MM Socket
Where can I purchase a 33MM Deep socket to remove my rear axle nut?
Old Jul 1, 2007 | 05:03 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
If you have acess to a 1 5/16" socket it might work.
Old Jul 1, 2007 | 05:07 PM
ROJ#79's Avatar
ROJ#79
Thanks for the info.
Old Jul 1, 2007 | 05:09 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
got mine at PEP BOYS
Old Jul 1, 2007 | 05:12 PM
02MillenniumVette's Avatar
02MillenniumVette
Here you go. Its a Snap On so it wont be cheap though.
33mm Deep Socket
Old Jul 1, 2007 | 05:23 PM
mrC5er's Avatar
mrC5er
Old Jul 1, 2007 | 05:24 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Napa sells them too.
Old Jul 1, 2007 | 05:31 PM
ROJ#79's Avatar
ROJ#79
30mm Deep Socket
Needs to be 33MM
Old Jul 1, 2007 | 05:33 PM
Jims99frc's Avatar
Jims99frc
I got mine at Advanced Auto parts , they had the actual "axle" socket . $12.99 .
Good luck .
Old Jul 1, 2007 | 05:43 PM
TEXHAWK0's Avatar
TEXHAWK0
O'Reilly's has a rack of larger sockets made for axle nuts. The 33 mm socket fits a lot of front wheel drive cars.
Old Jul 1, 2007 | 05:49 PM
02MillenniumVette
Originally Posted by ROJ#79
Needs to be 33MM
It is a 33mm, I just titled it wrong.
Old Jul 1, 2007 | 08:00 PM
BanditDude's Avatar
BanditDude
Sears should also carry them.
Old Jul 1, 2007 | 08:04 PM
ROJ#79's Avatar
ROJ#79
Good luck .
Thankx!
Old Jul 1, 2007 | 08:16 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Thankx!
Just make sure you got an air gun as they are a pain in the as@ to get off.
Old Jul 1, 2007 | 08:21 PM
vms4evr's Avatar
vms4evr
Mine came off pretty easy with just a breaker bar. Not really torqued much more than a caliper retaining bracket. It had been on the car for about 5 years. A little WD40 and lean on breaker bar. Done.
I got the socket at Carquest for about $15.
Old Jul 1, 2007 | 08:35 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
When the bearing is shot they generally come off easily...
Got mine at autozone too. Plenty in stock.
(side note, the side that had a "good" bearing was quite a ***** to get off)
Old Jul 1, 2007 | 09:30 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I thought it was 34mm? Is it 33?
To 33 MM Socket
Old Jul 1, 2007 | 09:41 PM
devnull's Avatar
devnull
Had to go look at it to be sure... It is a 34mm...
Old Jul 2, 2007 | 12:52 PM
ROJ#79's Avatar
ROJ#79
Thats what I was told on this forum a while back.
Maybe it is 34mm as Autozone and advanced told me they only come in even sizes
Old Jul 2, 2007 | 01:04 PM
z06Bigbird's Avatar
z06Bigbird
Keep the receipt. Some of that stuff is made in ?????
