[Z06] Front end Alignment for lowered Z
Old Jul 2, 2007 | 10:37 AM
The Wanderer's Avatar
The Wanderer
Default Front end Alignment for lowered Z
I have my Z lowered about 3/4-1" using the stock bolts. I am having the front alignent and I need to know if the specs are different for a lowered car? Could some one post the specs so I can print them and take to the shop doing it?
Old Jul 2, 2007 | 10:48 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
Check this out.
http://forums.corvetteforum.com/show....php?t=1505440
Old Jul 2, 2007 | 10:44 PM
99FewteRC5's Avatar
99FewteRC5
might want to think about doing a 4 wheel alignment
Old Jul 2, 2007 | 11:40 PM
pb24dagrk's Avatar
pb24dagrk
a little off topic, but how long do the stock shocks last on a lowered z06? how about cut bushings and longer bolts on rear?
Old Jul 3, 2007 | 06:07 PM
MarkT 2002's Avatar
MarkT 2002
With cut bushings and longer bolts I'ld say about 20 seconds. They get really stiff when you go that low and they will bottom out. I drove around two years on my stock shocks after I lowered my car all the way on stock bolts (bolts/bushings removed up front and rear lowered all the way with cut bushings) finally replaced them 10 months ago with Bilsteins Sports and it rides better and has never hit the bumpstops. I'm sorry I waited so long, and if I knew then what I know now I would have replaced the shocks when I lowered the car.
Old Jul 3, 2007 | 08:57 PM
ptindall's Avatar
ptindall
I bought my car with 99k on the clock and stock shocks. When I lowered it on stock bolts, the shocks suddenly felt stiffer. I do not hit the travel stops. I think I simply moved the pistons to an area that that was less worn out than at the stock height. Bilsteins are on my to-do list, but I'm in no hurry because they actually feel just fine. No float, body roll, or nosedive. I'm a little worried that when I put the Bilsteins on the car, it will get a lot harsher. A problem since a daily drive my car.
Old Aug 23, 2007 | 12:50 PM
ShadowLight's Avatar
ShadowLight
When people say they ride rougher, that's an understatement. When the back tires on my car hit a hard spot, I can practically feel my ***** somewhere in the area of my spine. Pretty bone jarring.
Still cool mod
Old Aug 23, 2007 | 05:50 PM
jnjboc's Avatar
jnjboc
Still cool mod
To Front end Alignment for lowered Z
