Headlight gear fix (highly pictorialized) - Page 9 - CorvetteForum - Chevrolet Corvette Forum Discussion
Old 08-18-2013, 08:55 PM
  #161
sebvegas
Junior Member
This is a great "how to" thread, and again, thank you very much, it helped me a lot to replace mine.
But I have a question though " despite everything works just fine and quietly, I can hear a little "bump noise" when the headlight closes.
Any idea anyone ?
thanks
sebvegas is offline
Old 11-18-2013, 08:33 PM
  #162
ScumOne
CF Senior Member
Thanks to Patches, and the others for tips/hints. My 04 CE got fixed up today but I got one of my mechanically inclined friends (with smaller hands than mine!) to help.
I ordered the complete set of bumper stops and metal gears for both lights from Rodney Dickman, they worked like a champ (included the T bracket and washers) on mine.
I was glad I did, when I opened the driver's side (which worked) there were bits of plastic already flaking off the gear, so it wouldn't have been long before that one took a dump and I'd be doing this all over again.
So thanks again, Patches, for the great write up!
Jim (no longer a one-eyed bandit in So Cal)
ScumOne is offline
Old 02-25-2014, 11:32 AM
  #163
Pseudomind
CF Senior Member
Pseudomind's Avatar
A couple of questions for T-Bar Install and headlight removal?
These are very good instructions by the way. Patches did an excellent job. I copied and printed them and have perused them a number of times.
1. Where exactly does the round white washer go when installing the T-Bar does it go between the T-Bar and motor cover? Where does it belong? I have seen no instructions which explain anything about this washer
2. Why has no one mentioned about just removing the top two headlight swivel screws and then just setting the headlight down inside the front well. With mine (2002 Convertible) once the actuator arm is disconnected and the headlight connections disconnected you can take the complete headlight assembly out. Look at this Youtube video
I got my brass kit from "Top Down Solutions" and it comes with a new rubber inside bushing with the gear, grease and the epoxy. I did as recommended and clamped and cured for 24 hours.
I still have not however been able to find out where the white washer included goes?
I will add this as well with the headlight up as you know you can turn the headlight control back half way and kill the lights. I did this then disconnected the battery. Once I had the assembly out I reconnected the battery and turned the lights to off. When I was ready to put my repaired assembly back in, I turned the headlight back on to raise the drivers side, obviously I wanted both lights to full upturned the headlight back to half off and then disconnected the battery again.
I would recommend before you reinstall the black bezel you complete all the assemble, reconnect the battery and lower the hood. I had to readjust the inside headlight cover screw, which you cannot do with the bezel on.
When you pull the motor note the actuator rods flat surface location. I marked mind with a china pin. When I put mind back in the flat side was off just a tad, so I removed the motors rubber cap and adjusted it back to the alignment then reattached the actuator rod
Pseudomind is offline
Old 09-27-2014, 08:40 AM
  #164
vets2vette
Junior Member
vets2vette's Avatar
Thanks Ed! I just finished with my gear swap, oh yeah, I tied a shoe lace to my ratchet wrench and secured it to the hood bumpers, so I was able to fish it out every time I dropped the @#!$ thing.
vets2vette is offline
Old 10-29-2014, 05:29 PM
  #165
NJD
CF Member
Ok, I replace my drive side motor completely. However, when I turn of the lights, the drive side head light will close, but then raise up again and stay in that position. Do you have any tips?
NJD is offline
Old 10-29-2014, 09:27 PM
  #166
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There are white plastic stops that the headlight stop against. See if they are cracked or missing. There are replacements that you can purchase from GM.
They Item #4 in the picture and they come in a kit with the spacers:
Bill
Bill
Bill Curlee is offline
Old 12-01-2014, 10:34 AM
  #167
rsl2715
CF Senior Member
Yep,my next project,parts on order new motors,also going with the brass gears.R
rsl2715 is offline
Old 12-30-2014, 12:30 AM
  #168
GCG
CF Senior Member
GCG's Avatar
Originally Posted by Patches View Post
...I clamped the cover snugly to maintain pressure while the adhesive cured overnight. I used the remaining adhesive to form a bead around the outside of the case/cover interface.
The next morning, I removed the clamps and checked for a good bond...
What's the size of the C-Clamps you used?
GCG is offline
Old 12-30-2014, 12:23 PM
  #169
Patches
CF Senior Member
Patches's Avatar
3" C-clamps
Patches is offline
Old 12-30-2014, 12:33 PM
  #170
GCG
CF Senior Member
GCG's Avatar
Thanks!
Sent from my DROID TURBO XT1254 using IB AutoGroup
GCG is offline
Old 06-07-2015, 05:16 PM
  #171
StealthStrike42
CF Senior Member
StealthStrike42's Avatar
Thank you, Patches!
Had the same issue as NJD, was trying to fix it via replacing the bumper stops. The bottom two were badly damaged. When trying to get them back on, one was no problem, second one was a real pain because part of the actuator arm had fallen far enough down to where it was blocking the lip where the new stop needed to go. I was following a YouTube video to try to remove the two screws at the top where the headlight pivots but could not get it off, I didn't have the right tools. Thanks to your guide I was able to remove the nut holding on that arm, move the arm, put on the new stop, and then throw the arm and nut back on and BAM! Problem solved.
Thanks again man
StealthStrike42 is offline
Old 12-19-2015, 04:23 PM
  #172
Chief3333
Junior Member
Default C-5 Headlight Repair
The article was well written and the photos were a big help, however, by necessity, I found another quick repair method for these headlight problems. As one author mentioned on this forum, the headlight motor only uses one half of the plastic gear to operate the headlight! Therefore, when you get to the point where you disconnect the linkage from the motor, try "manually" turning the headlight motor until the linkage shaft is 180 degrees from the point where you have removed the linkage. Replace the linkage arm, and you will find that your headlight works normally again!!! There is no need to take the motor off, or pry open the gear box!! It worked for me this morning.
Chief3333 is offline
Old 12-19-2015, 05:28 PM
  #173
Pappy11
CF Senior Member
Pappy11's Avatar
Nice............Thanks...........
Pappy11 is offline
Old 12-19-2015, 07:06 PM
  #174
Mr Russ
CF Senior Member
Mr Russ's Avatar
@Chief3333,
.....however the other side of the plastic gear will also eventually fail. Take it as a warning to get the brass gears, then do the repair at your leisure.
Mr Russ is offline
Old 12-20-2015, 10:43 AM
  #175
hdff
CF Senior Member
hdff's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
your right but the gear is plastic and now ~15 years old and more brittle so go ahead and buy the gears in the near future and study up on the procedure...
hdff is offline
Old 09-18-2017, 12:24 AM
  #176
2001CamaroGuy
CF Senior Member
Still a useful thread. Just fixed mine tonight!
2001CamaroGuy is offline
Old 09-18-2017, 07:34 PM
  #177
SDVette
CF Senior Member
SDVette's Avatar
2016 C1 of Year Finalist
I just fixed my driver's side motor with a metal gear.
Much thanks to this thread.
Looks like the grease has caked up and been pushed out of the way... may be the trigger that causes the failure.
One odd thing: I have a 98.. For some reason, 90% of the help and info is for later C5s.
The design is slightly different on the 98 (probably up to 2000).
The motor is not epoxied together - it's held by screws, and there is a gasket.
Also the configuration of the bolts holding the motor in is different - there is only 1 with a nut, the other 2 holes are threaded.
Take care to note the position of bushing and spacers on both sides of the gear... they need to be re-used (at least my kit didn't include new ones)
Fred
SDVette is offline
Old 09-19-2017, 08:10 AM
  #178
CPO Rob
CF Senior Member
CPO Rob's Avatar
Great Post. This is a keeper for sure
CPO Rob is offline
Old 09-19-2017, 08:39 AM
  #179
C52002Vert
CF Senior Member
C52002Vert's Avatar
C52002Vert is offline
Old 09-23-2017, 11:21 PM
  #180
corvet786c
CF Senior Member
corvet786c's Avatar
In Rodney's kit, where do the small rubber o-ring go? The ones with the metal T in same bag?
corvet786c is offline
Quick Reply: Headlight gear fix (highly pictorialized)
Sponsored Ads
Vendor Directory
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
