HOW MUCH $$$ radiator flush and rear differential flush
Old 08-08-2007, 06:09 PM
BULLITT3143
BULLITT3143's Avatar
Default HOW MUCH $$$ radiator flush and rear differential flush
how much does it typically cost to get a
radiator flush-
rear differential flush-
individual prices please
and what type of fluids should i use for each. i plan on having it done soon. thanks in advance
todd
Old 08-08-2007, 06:12 PM
max'svette
max'svette's Avatar
St. Jude Donor '11
For the rear $99 use royal purple..
Radiator $100-150 use Dextron or fluid of your choice.
Old 08-08-2007, 06:59 PM
BULLITT3143
ttt
any others
Old 08-08-2007, 09:03 PM
BULLITT3143
ttt
Old 08-08-2007, 09:18 PM
$$$frumnuttin'
$$$frumnuttin''s Avatar
Location: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Dextron at the local Chevy dealer....$95 and I had a 15% off coupon from GM!
Old 08-08-2007, 10:28 PM
BULLITT3143
ttt
Old 08-09-2007, 09:32 AM
BULLITT3143
Ttt
Old 08-09-2007, 10:56 AM
BULLITT3143
ttt
Old 08-09-2007, 11:04 AM
docbrew
docbrew's Avatar
Did both myself in one afternoon for the cost of the fluid. Cant beat spending some quality time with the vett on nice day.
Old 08-09-2007, 01:36 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,910 Likes on 5,325 Posts
Do the radiator flush yourself. Pull the cap, open the radiator petcock and catch the old fluid in a large pan or bucket. Refill with clean drinkable tap water and drain again. Repeat until clear. Then add proper amount of Dexcool (6.3 quarts) to get a 50/50 mix of antifreeze/water in the cooling system and top off with water if not full. If you use a 50/50 premix you will be low on antifreeze as an undefined but significant amount of water is retained in the engine when the radiator is empty.
WalMart usually carries the original Texaco DexCool.
Bill
Old 08-09-2007, 01:40 PM
mkenyon
mkenyon's Avatar
Dealer in MD quoted in July for me:
$175 for Rear diff flush, fill
$145 for Coolant flush, fill
Actual charges were slightly less, but close.
Old 08-09-2007, 02:14 PM
C5'S LS1
C5'S LS1's Avatar
Default Something to think about...
I am the second owner of my 99 Coupe.
When I picked up the car from the previous owner, He had told me that he has never put tap water in this car. He would take his own distilled water to the dealer.
I have done one radiator flush and followed his same plan.
Dextron mixed with only distilled water.
With distilled water, all the minerals & deposits have been removed.
No dirty water = less electrolysis, less maintenance, longer lasting parts
Old 08-09-2007, 03:13 PM
LoneStarFRC
LoneStarFRC's Avatar
Location: Dear Karma, I have a list of people you missed.
Why the need for "flush" in the diff? Unless you have some specific contamination issue to address, "flushing" is a waste of time and money.
Drain and replace fluid? Yes.
Old 08-09-2007, 03:44 PM
mike348
mike348's Avatar
Used Dealer Internet Coupon For Radiator Flush $69.00
Old 08-09-2007, 08:29 PM
BULLITT3143
ttt
Old 08-09-2007, 09:24 PM
$$$frumnuttin'
I should add, I went 10 years with the original coolant...never added a drop. I had it flushed because I got scared after reading some horror stories on the forum. When I picked up the car I asked the corvette mechanic how the coolant looked. He said it was clean as could be...I was quite surprised. When I gave it some thought I realized I only had about 5 years service on the engine because it is stored 5-6 months/year...now it makes sense.
Old 08-10-2007, 12:13 AM
wamara
wamara's Avatar
Cruise-In II Veteran
Errrr, I don't think it quite works that way, but I'm glad you didn't have a problem
To HOW MUCH $$$ radiator flush and rear differential flush
Old 08-10-2007, 07:58 AM
stormrider
stormrider's Avatar
You where very very lucky! I wasn't and it cost me over $700
Old 08-10-2007, 08:23 AM
cruisemon
cruisemon's Avatar
Bill
It's better to use distilled water with DexCool and aluminum. Local Kroger sells distilled for about 80 cents a gallon. It's cheap and takes another variable out of the equation. Search Google for DexCool complaints, grab a six pack and sit back for a LONG reading session. Tap water in some areas has really high mineral content and can cause problems.
Charlie
Old 08-10-2007, 11:59 AM
Biggreen99
Biggreen99's Avatar
Just had this done recently at a local vette shop for my newly acquired '99, along with a few other things. Radiator flush w/ Dexcool was $135. Rear diff drain & refill was $116.
Quick Reply: HOW MUCH $$$ radiator flush and rear differential flush
