OK, my 99 finally aquired this common fault. My windows, and my door locks, both sides, don't work. I know this has been discussed before, and I have studied the threads posted. I have the drivers door apart now. The only relay that will work is the drivers lock open relay. What are the relay part numbers for both the locks and windows. I can only find a part number for the lock relays. And do you think its better to bite the bullet and buy the whole control module ($270.00) or try to replace the relays ? I know it takes a couple of special tools to remove the relays. And does the left side failure create the right side failure, or are both sides going to have to be replaced, or repaired ?
