Long Tube Headers Ques...
Old Sep 23, 2007 | 09:56 PM
ALVETTE00's Avatar
ALVETTE00
Default Long Tube Headers Ques...
When you install long tubes, do you still retain the cats?
If not, how do you pass emission tests?
Thanks,
al
Old Sep 23, 2007 | 10:04 PM
Touch of Fast's Avatar
Touch of Fast
You can use hi flow cats or no cats. Without cats you won't pass emissions, but you will have great sound, more power and serious fun.
Jerseyvinny's Avatar
Jerseyvinny
Had kOOKS long tube headers put on at Cartek in Garwood, NJ. They installed them with high flow cats. Haven't put the car through inspection yet. So the answer is you can still use cats.
Old Sep 23, 2007 | 10:08 PM
moserbe's Avatar
moserbe
ECS in NJ put American Racing long tube headers and hi-flo cats along with an x-pipe onto my 98. Nice difference in both the sound and the performance.
Old Sep 24, 2007 | 10:03 AM
ALVETTE00's Avatar
ALVETTE00
Another dumb question:
Can you use the stock cats, or is that not recommended?
Thanks!
Old Sep 24, 2007 | 10:37 AM
81c3's Avatar
81c3
You probably could use the stock cats with some adapters, clamps & maybe some welding skill....but why? Go with a nice hi-flo cat.
Old Sep 24, 2007 | 10:40 AM
jon c's Avatar
jon c
Thanks!
I would think that you are backing up by using stock cats with the LT headers, you would be causing a flow backup....
Old Sep 24, 2007 | 10:43 AM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
I did both....hi-flow got me only 6 more rwhp. It was much louder and deeper but performnce was not much. IMO not worth the money. Biggest problem you will have are with the oxygen sensors.
You can buy sims and plug them in or just go into your dic and take the codes out
Old Sep 24, 2007 | 01:09 PM
LLVETTE's Avatar
LLVETTE
I used the stock cats with LT's. From what I've read the stockers flow pretty well and the high flow cats only get you a couple of HP over the stockers.
Old Sep 24, 2007 | 01:15 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Most of the good header kits will come with hi-flow cats, or give you the option to go catless. I run hi-flow cats, mainly do the smell of running with out cats all together. I am not sure about emissions in PA, I would think they are about the same as in IL... Don't get O2 sims, not worth the money several people I know tried this route and its just too risky the sims are not reliable someties..if I were you, I would go get a dyno tune after you put the headers on to get the O2's shut off to pass emissions (at least that's how we pass in IL since all they do is plug in to the OBD port, no codes and you pass, no visual inspection).
Old Sep 24, 2007 | 04:35 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I got Hiflow cats on mine! and it passed California Emissions tests!
Thanks,Matt
Old Sep 24, 2007 | 04:40 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
No cats, no emissions tests (YET)
Old Sep 24, 2007 | 07:45 PM
csexton's Avatar
csexton
ECS installed ARH LT's and high flow cats. Great performance and sound with my Corsa Pace cars.
Chuck
Old Sep 24, 2007 | 09:36 PM
DDNZ06's Avatar
DDNZ06
Default This has been on my mind for two weeks now...
Thanks for asking this question. I have to get mune inspected before the end of the month.
I have LG LT's w'out cats.
I will order some tomorrow. I hop eto have them on this week and go take the test.
I did have a friend here in IL that said I should pass as long as they don't inspect the car - but I'm putting high flow cats on - just in case...
Old Sep 24, 2007 | 10:05 PM
fdxpilot's Avatar
fdxpilot
I have LG LTs. The tubes are long enough that the end of the collector is in the same area as the stock cats would be, making connection to the stock cats and H-pipe a pain. I went with the LG hi-flow cats and x-pipe (including all 4 O2 sensors) and passed two emissions (sniffer) tests in TN prior to moving to a no-test state.
Old Sep 27, 2007 | 03:42 PM
DDNZ06's Avatar
DDNZ06
Default Just Passed the Illinois Inspection
All they did was connect to the OBD2 jack and send me on the way. A couple of comments on how nice my car looks and thats it...
I sure am happy - I wasn't looking forward to getting under the car again to install some hi-flow cats...
Old Sep 27, 2007 | 04:15 PM
BOTYNV1's Avatar
BOTYNV1
Is the inspection a Cook County requirement?
Old Sep 27, 2007 | 04:28 PM
SUPERCRUZ's Avatar
SUPERCRUZ
Hello. I live in Northern VA an they do an OBDII emissions test every two years. From what I understand, the system checks for active MIL lights or a history of MIL. You can clear codes on the C5 but there will be history which only gets cleared after a certain number of drive cycles without the problem showing up.
I recently had LT installed and opted for the Hi-flow cats due to emissions. However, I have heard that even with hi-flow cats and O2s working that some cars will still throw an MIL on the rear O2s anywhere from a few 100 to a few 1,000 miles. Think this has something to do with the reduced back pressure and difference in O2 readings from front to rear. I was told the best course of action is to leave the front O2 operatonal and have the tuner tune out the rear O2s. This way you eliminate any chance of rear O2 MIL and you should pass emissions using OBDII check. In VA, if you fail OBDII check, you have one more chance with the OBDII test and then they run a sniffer test. With the above setup, you should be fine. I have another year before I have to test mine but so far no MIL lights and I have been running LTs for about a month.
IMHO if you are going to the expense of putting LTs on, get the hi-flow cats. Most systems like the ARs have a hi-flow cat configuration in the design setup. Trying to use the stock cats is just too much work in my opinion for the money you may or may not save. Good luck with it.
To Long Tube Headers Ques...
