[Z06] 102 octane racing gas
St. Jude Donor '08
Aviation Fuel
Another thing about Av-gas is that most of it is oxygenated to allow for the thinner air at altitude. I'd stick w/automobile specific fuels like those from VP, Sunoco, et al.
Also stay w/the Top Tier fuels for keeping your injectors & valves clean & deposit free.
http://www.toptiergas.com/
TOP TIER Gasoline Retailers:
QuikTrip
Chevron
Conoco
Phillips
76
Shell
Entec Stations
MFA Oil Company
Kwik Trip/Kwik Star
The Somerset Refinery, Inc.
Chevron-Canada
Aloha Petroleum
Tri-Par Oil Company
Shell-Canada
Texaco
Petro-Canada
Sunoco-Canada
Gee - I wonder WHO I work for??!!
Gene
QuikTrip
Chevron
Conoco
Phillips
76
Shell
Entec Stations
MFA Oil Company
Kwik Trip/Kwik Star
Chevron-Canada
Aloha Petroleum
Tri-Par Oil Company
Shell-Canada
Texaco
Petro-Canada
Sunoco-Canada
Gene
I have run cheap mom and pop gas station regular in 4 of my vehicles bought new since day 1 (a 99 Dodge 4X4 with 65K, 2001 4X4 Expedition with 62K, 2002 Dodge Neon with 66K and 2005 Toyota 4X4 with 51K). All 4 of those cars run as well today as they did the day I bought them and gas mileage has not wavered any less either. I have never put anything other than 86/87 octane regular in all of them and never had a miss, stumble or anything breakdown related to engine. Not one of them has had anything other than oil changes and air filter replacement done. 3 of our other vehicles see 91 octane premium as they require it for their compression ratios and they of course are all running fine also.
Our 2 race/street cars see leaded racing gas and they run really well.
I buy whatever is the cheapest in town on the cars I own and have never had a problem.
QuikTrip
Chevron
Conoco
Phillips
76
Shell
Entec Stations
MFA Oil Company
Kwik Trip/Kwik Star
Chevron-Canada
Aloha Petroleum
Tri-Par Oil Company
Shell-Canada
Texaco
Petro-Canada
Sunoco-Canada
Gene
QuikTrip
Chevron
Conoco
Phillips
76
Shell
Entec Stations
MFA Oil Company
Kwik Trip/Kwik Star
Chevron-Canada
Aloha Petroleum
Tri-Par Oil Company
Shell-Canada
Texaco
Petro-Canada
Sunoco-Canada
Gene
http://www.vpracingfuels.com/vp_01_fuels.html#leaded
My customer owns a Mobil station and he layed down the facts to me. there is no true mid octane such as 89.All stations have mixing valves that mix low and high grade to achieve this grade.When the pump says min 89 octane rating you will not have less then 89 and could be as high as 93.This also goes for 87 were you can go as high as 93.Now 93 will have a min of 93 but can go as high as 96.He tells me its often they test higher then there numbers.No stock vette needs anything but 87 unless tweaked or s/c etc.He is the first to tell you mid grade is a waste of money and his biggestmoney maker.Last thing all Mobil gases have the same additives and detergents.Hope this could help shed some light on this.
St. Jude Donor '08
Not Always!
Yes, I've also have worked on the distribution side of the business so I've seen some LOCAL stations do some "not so honest" things but for the most part, what U pay for is what U get.
BTW - all of our gasolines contain detergent additives as well. That's why we have achieved & maintained Top Tier status. Sorry if I'm blowing my company's own horn but I don't see Exxon/Mobil on the current T/T list ( despite their record profits!! ).
Gene
What is wrong with mixing a properly weighted blend of 87 octane and 93 octane at the pump to obtain 89 octane gas? This seems perfectly legitimate to me and, unless I am missing something, having a third tank seems like a waste.
I have made my own octane rating many times by combining properly proportioned amounts of different octane gas. I even recall Sunoco stations back in the 1960s having an octane selector on the pump. You could choose about 5 different grades all the way up to 103 octane. I am certain that they didn't have 5 different gas tanks in the ground.
They don't mix to get midgrade
From the API (American Petroleum Institute) ...
Manhole covers to tanks are recommended to be colored according to American Petroleum Institute (API) standards (white - unleaded, blue - midgrade, red - premium, yellow - diesel, brown - kerosene).
From the US Govt site (Energy Information Admin) ..
Midgrade gasoline: Gasoline having an antiknock index, i.e., octane rating, greater than or equal to 88 and less than or equal to 90. Note: Octane requirements may vary by altitude.
Midgrade is blended by the refinery, or by the distribution company ... or in some cases SOME fuel pumps are set up to blend as you fuel .....
http://www.benfordfueling.com/shop/product445.html
Note that the service station is not blending the fuel ahead of time, the pump is set to create the "blend" on the fly.
I suspect these are not allowed in California as the CARB maintains VERY strict standards for gasoline, and probably won't allow blending at the station.
