Cross Beam Adapter Mods
I have seached the forum and have found several articles about lifting the corvette with the cross beam adapter and some of the mods to make them work better. I recently purchased two sets and need to shorten one. Most of the forums info shows pictures of the mods, but do not give any dimensions.
Instead of just modifying one set by placing the pad on the ends of the center tube, I would like to shorten the inserts and cut off some of each end of the center tube to allow for adjustments and have the ability to use the jack screws for adjustments.
Car put away for the winter and I can't get under it.
Does the C5 and C6 have the same configuration on the front and rear cross beams.
Does anyone have the dimensions?
Any help would be appreciated.
