How to eliminate brake dust?
I went with the Delco ceramic pads when I got my new chrome wheels and it reduced the dust by quite a bit although it did not eliminate it. I do not see a loss of stopping power either. Cost was $175.00 and I installed them myself. Great time to paint the calipers also.
Brake Dust Shields
Hi, I used "Kleen Wheel Brake Dust Shields" on my Mustang GT . I put them on when I bought the car in 89, and they kept the wheels as brand new for 17 years. Not a drop of brake dust. They absolutely work as described. I never experienced any heat problems from them, as they have slots in them to direct the airflow over the pads but not the other diriction. The only downside is that you cannot see the disc and calipers as it comes from the factory. They are super light weight aluminum and are painted Matte Black, so you can paint them any color you want or leave them black if that is your preference.
They work, and they come in the vette sizes. Installation is easy, you just remove the wheel and press them in from the back, bolt the wheel back on and done. For street cars I can't see a problem.
Good Luck
Good Luck
Received 3,812 Likes
St. Jude Donor '03-'04
Here is the real question
the harder the brake pad compound, the less dust. WE did a study of BMW's brake pads together with their system. BMW is the world leader in brake safety and design... they have the best numbers on stopping in cold stop ( Panic stops ). BMW's brakes are the dirtiest brake pads and last the least amount of time but they will save your life.. AT GM we wanted the best compromise between stopping and longevity. Thats why we chose the ACdelco pads that came with the car. They dust, thats a good thing, because that dust is what is keeping your pads from fading. Now add some hardness and you get less braking, but it makes those who cry about brake dust happy...
Now here is the scenario.. Your on the supper highway safely behind a Panel truck your cruising comfortably at 70 mph and the panel truck and you go around a slight turn in the highway and all of a sudden the truck swerves into the next lane, and 120 ft ahead is a complete standstill, you hit the bakes and the abs works and you stop 5 ft before you slam into the stopped cars... Now add dustless or less dustless pads, or worse yet you add ceramics which require some heat up to give full stopping power.. all of a sudden your bake stopping power is decrease by 15 % this add 20 ft to the above scenario putting you about 15 feet into the stopped cars. These dust free brakes will stop your car and you wont notice any difference in stopping power under nominal driving conditions. But you may only get one chance in life to do a successful Panic stop.. the other scenario I mention is a deer in the road.. you have two choices swerve to avoid the deer, but statistics show that swerving is usually fatal, because the situation usually occur on a highway with cars on other lanes, and its these cars that will kill you, your much better off trying to stop. MY point to this, is do you want to risk your life because your too lazy to wipe down your wheels... I would always want to get the softest most stoppable pads I can find, and the original AC Delco pads are my choice only because of the data... the ceramics are GM's answer to high brake dust on these cars, not quite as good as the originals but a compromise. Next time you're next too a BMW, take a look at their wheels, they are driving one of the safest cars on the road, with the best stopping ability. Your Corvette comes from the factory as a close rival to the BMW system. Its a shame that so many people want to change things for the sake of change. IN this case, a change for the worse.. Bakes are designed to stop your car, as quickly and as safely as possible, without regard for their cleanliness. I wont debate this or respond again in this thread, if you have any questions PM me.
Bill aka ET
Bill aka ET
Bill aka ET
Bill aka ET
Received 19,218 Likes
'20-'21-'22-'23-'24
Bill aka ET
Bill aka ET
#35
Brakes are for STOPPING not Shining the wheels
As others stated, ceramics will do the trick. Problem with them is they start to fade baaaaddddd after a few hard stops. For most street driving, they should be fine, but some have reported issues in heavy traffic where heated up, they just don't stop as good.
Personally, I perfer the brakes to stop the car. I can wash brake dust off. I can't repair body work or re-incarnate myself.
#37
The more I read ET's posts, the more I realize how well thought out and built this car really is. Love my vette, even with all the little quirks.
#38
Glad I just got a new set of AC Delco OEM's installed.
I'd rather be able to stop and wash my wheels when they get dirty.
I know, I dug up an old thread as I was doing a search on new rear brake pads, but E-T sure as heck speaks the truth and makes perfect sense.
#40
Received 1,673 Likes
Yep, ceramic pads will help. I use Raybestos Quiet Stops.
