Brake Fluid ????
Mar 9, 2008 | 04:35 PM
Brake Fluid ????
OK Guys , Last week I learned NOT to use Silicone Brake Fluid. So today I went to buy DOT #3 . Now I see the auto parts store carries Three different brands of SYNTETIC fluid and one of regular. My question is ....should I use the regular or the Synietic? Your advice PLEASE. I have a 98 C5. Wayne Pec
Mar 9, 2008 | 04:45 PM
The book says:
Delco Supreme 11 Brake Fluid (GM Part No. 12377967 or equivalent DOT-3 brake fluid).
Mar 9, 2008 | 05:12 PM
I know , or think I know that in 1998 DOT#3 was the only choice. But today is the Synthetic a better choice?
Mar 9, 2008 | 05:14 PM
You'll get about 20 different opinions here
Mar 9, 2008 | 05:19 PM
I used synthetic in mine.
Mar 9, 2008 | 05:44 PM
St. Jude Donor '20
Put in Valvoline SYN Power. Meets or exceeds DOT 3 & 4 and compatible with conventional bf.
Mar 9, 2008 | 06:04 PM
Thats my concern,COMPATIBLITY. On the bottle it just says ADD according to mfg specs. But what is the long term effect? Or is there one?.... I plan on doing a complete change,......if there is such a thing.
Mar 9, 2008 | 06:27 PM
St. Jude Donor '20
Quote:
Originally Posted by
pec98
I switched out as much as I could. The fact that Valvoline SYN is compatible with conventional brake fluid tells you that any oe fluid left in the system is O.K.
Mar 9, 2008 | 08:22 PM
Some info regarding DOT 4 fliuds here:
http://forums.corvetteforum.com/show...+4+brake+fluid .
I use the ATE Blue and ATE Gold. Reasonable priced, and good wet boiling point. The downside is you won't find it at the local autoparts store.
Mar 9, 2008 | 08:28 PM
Valvoline Syn Power.
Mar 9, 2008 | 08:32 PM
waunavet
If your a male, try not to use compatible and bf in the same sentence lmao!
Just messin with you man!
Mar 9, 2008 | 11:16 PM
Valvoline Syn Power
the last 4 years in all my cars.
Mar 9, 2008 | 11:38 PM
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
rws.1
Valvoline Syn Power
Sweet,
Having my brake fluid bled when the SS brake lines,rotors,
calipers,well you get the picture,the whole nine-yards.
The right topic always comes up at the right time.
Val Syn Power sounds like a winner,I'll be stopping
at the Zone for a few bottles.
Mar 10, 2008 | 01:51 AM
ATE TYP 200 Dot 4 (non syn), has a better boiling point than syn dot 3 or 4 and its not that expensive
Mar 10, 2008 | 06:58 AM
St. Jude Donor '05-'08
rws.1
Valvoline Syn Power
been using for the street for some time now. For the track I use Wilwood.
Mar 10, 2008 | 08:36 PM
St. Jude Donor '20
1sickz51vette
I'm am and I did. I now see the error in my ways.
