Help: Installed HID kit and now problems :(
1) Put the key in, turned to ACC, and turned on headlights, then went back to parking lamps
2) With headlights still up I popped the hood and disconnected the battery
3) Removed low beams, installed HID kit
4) Used manual adjuster to move right headlight up and down to check for clearence
5) Everything cleared fine so I put it all back together
Here is where the problems start:
6) Get back into car, turn **** back to 'Off' for headlights
7) Reconnected battery
8) Started car
My headlights wont go up or down now, they are stuck up. If I flick the high beams or go from off to back on, nothing happens, the HIDs wont fire nor the lights will go up or down. The high beams do still work though....
I checked the fuse box and everything in there looks good. So what now?
Edit: I got the exact same kit as 2004 Z06 in this thread: http://forums.corvetteforum.com/show....php?t=1970375
I specifically bought this one because he reported no problems with it.
8) Started car
1) If I leave the high beams on, and turn the lights off, they go down. Once down if I turn them back on into high beam mode they will go back up.
2) If I get them down using the high beam trick, and I turn them on, the headlights will go up but the bulbs will not fire. Now I am starting to think there is another problem other than needing a relay or resistor because I cant get the ballasts to ignite.
Bulbs have three leads on them. 2 single connectors, go to the 2 single connectors of the ballast. Can't get these wrong.
LONG double connector goes to the ballast. Can't get that wrong.
SHORT double connector goes to the factory harness. This is where you can get backwards! Make sure that when you plug the SHORT one to the factory harness that you have the colors matching. Black to black, red to red, blue to blue, whatever color wires you have. This should get them to fire.
The up/down issue will most likely always be there.
Let us know how you make out.
Only thing I didnt do was manually close and open the headlights to check for clearence.
If the ballasts aren't firing up I'd send them back.
Went and switched the plug to the 'wrong' way, and electrical taped it to stay in place and now everything works as it should.
Thanks for all the help.
Edit: You can actually see in the last pic of 2004 Z06's post he has them also plugged in the "wrong" way....that's how i figured out my issue.
Well if its not broken, dont fix it right.......I'll leave mines alone
Glad everything worked out
Thanks Milan
