Fob
Fob
Had PCM removed and tuned. Ofcourse I diconnected neg. battery terminal. Everything is fine except both fobs inop. Both worked fine before. Battery was disconnected for 5 days but have driven 100 miles with no issuses. Re-program?
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
No need to reprogram I think. All you need to do is re-sync.
Get the FOB close to the car then press and hold down the lock and unlock buttons at the same time. The car horn should chirp after a few seconds to let you know the FOB is re-synched.
Repeat for other FOB.
