Fob Question
Old Apr 16, 2008 | 10:43 PM
O4-/-C5's Avatar
O4-/-C5
Default Fob Question
I have a 98 Passave FOB with Key. GM 10253839
Is the Key of any value in the sale of this unit or is it specific to a car.
Old Apr 16, 2008 | 10:45 PM
Junkman2008's Avatar
Junkman2008
No, the fob can be programmed to work with any 97-2000.
Old Apr 16, 2008 | 10:46 PM
jdmvette's Avatar
jdmvette
Night Owl for life
isn't the key for starting the engine?
Old Apr 16, 2008 | 10:49 PM
O4-/-C5's Avatar
O4-/-C5
Yes - but will the key be good for all cars. I know the FOB can be programed.
Old Apr 16, 2008 | 10:55 PM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Hmmmmm someone will chime in... As I recall you have to get it programmed at the dealership for the "key" to work in the ignition...in order to actually start the car...
Is it a key blank with a chip or just a key blank and no chip?
Old Apr 16, 2008 | 10:56 PM
jdmvette's Avatar
jdmvette
Night Owl for life
the pellet on the key has a designated resistance value and i believe there are a total of 16 different values.
the key would have a 1 in 16 chance of working with another car if it was cut for that car.
Old Apr 16, 2008 | 10:58 PM
Junkman2008
the pellet on the key has a designated resistance value and i believe there are a total of 16 different VATS values.
Exactly. If the key has already been cut, it is worthless for the most part to anyone else.
Old Apr 16, 2008 | 11:04 PM
O4-/-C5's Avatar
O4-/-C5
Its a cut key with a chip.
Old Apr 16, 2008 | 11:08 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
I have a FOB that I "Lost" for a while, then it was "found" but doesn't work anymore. Not trying to steal the thread, but can someone help?
Old Apr 16, 2008 | 11:12 PM
O4-/-C5's Avatar
O4-/-C5
I believe there is a battery in the FOB. Maybe its bad.
Old Apr 16, 2008 | 11:19 PM
97C5owner's Avatar
97C5owner
The FOB will work on any 97-99 after programming. Let me know if you need instructions for programming. The chip in the key has 1 of 16 different levels of resistance which can be measured if you have a digital ohm meter. If the key has been cut, it is, for the most part, usless to anyone else. If it's still a blank its worth about $10 if you can find the chips resistance. streekeys.com sells keys with chip programmed for $10 so it's probably not worth your trouble.
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Battery could be bad or it justs needs to be "re-learned" If you have previously programmed that FOB to that car, you can "re-learn" it by hiolding the lock and unlock buttons down at the same time for a few seconds until you hear the horn chirp. You should be successful from that. If it doesn't chirp, you may need to re-learn it to the car... more indepth process for this... It's all over the tech section.. do a search if this doesn't do it.. with a new battery.
Old Apr 16, 2008 | 11:27 PM
O4-/-C5's Avatar
O4-/-C5
Thank you. That answers the question about the key. Thats what I thought but just wanted to be sure. I will not include the key in the sale.
Old Apr 17, 2008 | 01:42 AM
DeeGee's Avatar
DeeGee
Here are the VATS values
The resistance of the key matches the programmed setting for your car. The BCM senses the resistance and if it's within 10%, the car starts.
The resistor codes are:
Key number Value (Ohms)
1 392
2 523
3 681
4 887
5 1130
6 1470
7 1870
8 2370
9 3010
10 3740
11 4750
12 6040
13 7500
14 9530
15 11800
Rather than measure it the dealer can check the value based on your VIN.
Old Apr 17, 2008 | 01:45 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i measured mine with a meter when i was getting a corvette key switchblade made up. the value was pretty spot on to those specs.
Old Apr 17, 2008 | 02:40 AM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
Now that its cut, its only good for that Vette.
Paul G.
Old Apr 17, 2008 | 11:23 AM
O4-/-C5's Avatar
O4-/-C5
Paul G.
To Fob Question
