Headlight not flush
My problem is the headlight on driver's side goes down too far & is not mounted flush.
I raised it with the ****, but after ging up & down with the switch it stops below the flush point.
Anyone know what I need to do to make "Flush"
Raise the headlamp doors and remove the 3 screws on the black bezel. There are two at one side and one at the other.
Remove the 2 torx screws on the side of the cover and than lift the headlamp cover off and put it safe
There are 4 white capped screws which adjust the height of the cover. Turn them clockwise to lower and counter-clockwise to raise.
Reassemble and check for the fit. You may need to do it a few times as its trial and error to get it right.
BUT....make sure to turn the torx head inside the white capped screws, NOT the white caps themselves.
