How hard is catback install?
Old May 11, 2008 | 11:34 PM
futuretech's Avatar
futuretech
Default How hard is catback install?
I have turned a wrench or two and am wondering how difficult it is to put Corsa's on using jackstands.
Alos what should it cost if I call a local shop instead?
Old May 11, 2008 | 11:41 PM
3318C5's Avatar
3318C5
I would check their website to see if they have a pdf with instructions. I installed the borlas I have on my car myself. The only forseeable (spell check... ) problem that I could see doing it on jack stands is having enough clearance to remove the stock exhaust.
Mike....good luck!
Old May 11, 2008 | 11:43 PM
EllisJuan350's Avatar
EllisJuan350
Its easy...if you dont want to keep your stock exhaust(all youll need is a hacksaw)
if you can get ahold of a lift you will have no problems
Old May 11, 2008 | 11:45 PM
diyguy's Avatar
diyguy
I would not even think about it on jackstands. you really need a lift to do it, or at least to get the stock exhaust out.
Not enough room to get the exhaust pipe up and over the rear axle without getting it very high up in the rear. It helps to drop the rear sway bar, but even still it's a 15 minute job with a lift.
Do a search and you'll see some have done it in the garage.. Extremely dangerous. A chance of slipping off these crazy home made ideas make me shake just looking at them.
Old May 11, 2008 | 11:47 PM
futuretech's Avatar
futuretech
Thanks guys. What is the level of difficulty? Just want to make sure I am not half done and have one of those Aw sh!!t moments lying on my back and regret not taking it to the shop.
Old May 11, 2008 | 11:48 PM
futuretech's Avatar
futuretech
Thanks, just the words of wisdom I needed!
Old May 12, 2008 | 12:07 AM
itzza427's Avatar
itzza427
It is not hard.It is much easier if you "drop" the sway bar,1 bolt and 1nut and bold each side at the middle mount /bushing.This gives you enough room to maneuver the pipe/muffler. 2 bolts for each pipe flange. a novice should be able to do it in about 30 to 45 min. Knowledgeable pros should take about 10-15 min. tops.
Old May 12, 2008 | 12:17 AM
White Rabbit's Avatar
White Rabbit
Took me an hour in my driveway, i just cut off the stock setup and bolted up the Borlas...
Old May 12, 2008 | 12:18 AM
jrose7004's Avatar
jrose7004
Much, much easier with a lift. It's hard to get it high enough on jack stands.
Old May 12, 2008 | 01:32 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
If you want your stock exhaust out in one piece, you need to get the back of the car up 36 inches off the ground.
If you do not want your stock exhaust (it's worthless) than you can cut behind the mufflers and it will drop right out using just jack stands...
Difficulty is a 2
Peace
Chip
__________________
..................Click for
Old May 12, 2008 | 06:24 AM
vetter79's Avatar
vetter79
Old May 12, 2008 | 07:21 AM
rws.1's Avatar
rws.1
Just a few bolts on the exhaust flanges, sway bars and gas tank shield.
It is a high lift with a floor jack.
We needed to make a sandwhich of a 4/4 and 2 -2x6's to use as a lifting pad on top of my jack to get the necessary height.
twist, turn and wiggle the old exhaust to get it over the axle
use a short piece of 2x4 under the exhaust tips and lift in the middle with a second floor jack to lift the tips and make them all the same height...
then tighten all the alignment bolts.
Old May 12, 2008 | 07:35 AM
blkdevl's Avatar
blkdevl
on a scale for skill it is a 1.5 so easy. 1 is replacing wipers and 10 is rebuilding your engine. dont be scared of having it that high up on jackstands plenty of people on here have done it that way and no one has died! just dont half as$ it. or just cut your stocker off and youl have it done in half the time and half the hight.jmho
Old May 12, 2008 | 09:30 AM
tellefan's Avatar
tellefan
If you have an automatic, you need to remove the heat shield on the right gas tank. Most folks keep their stock exhaust intact. That way when you go to sell your car it can be reinstalled and sell the cat back used. David
To How hard is catback install?
