Question about Vararam install.
Old May 19, 2008 | 02:03 PM
HillBilly Vetteman's Avatar
HillBilly Vetteman
Default Question about Vararam install.
OK...I installed mine over the weekend...I have large hands...now they are cut up...but...when putting everything back together I noticed a plug that had no place to go. I'm wondering what it does. I don't recall unplugging it at the beginning of the install. I'm including a picture to show exactly which plug...the photo is from above on the passenger side...the guy is pointing right to it. I took everything back apart looking for a spot to plug this sucker in...and found nothing...I do not have fog lights...could this be a connector for fog lights? The car runs fine...but I need to make sure. Any help is appreciated.
Old May 19, 2008 | 02:22 PM
wildbadbill's Avatar
wildbadbill
I think it's for the underhood light.Look on your hood above the plug if you see the connector...
Old May 19, 2008 | 02:38 PM
veni vidi vert's Avatar
veni vidi vert
external temp sensor??????.....
Old May 19, 2008 | 02:41 PM
BowTieRocket's Avatar
BowTieRocket
Actually, that's the OAT sensor. Outside Air Temperature. Look up from under the nose of the car (on ramps or some such), and you'll see a little bulb sticking through the plastic radiator shroud. Be careful - it's a little delicate. Not expensive or hard to replace, though. I messed mine up with one of the debris screens, and had to cut a clearance around the sensor to give about a quarter inch of room.
Old May 19, 2008 | 02:49 PM
HillBilly Vetteman
I swear I couldn't fine this anywhere. I had to remove the plastic radiator shroud. Used a flashlight while the car was up on ramps and didn't see a thing. Where does the bulb originate from?...or...more importantly...what is the purpose of it?
Old May 19, 2008 | 03:14 PM
rws.1's Avatar
rws.1
It is the sensor that lets your A/C unit show you the outside temperature and shuts off the A/C when it gets too cold...
Old May 19, 2008 | 03:19 PM
rws.1's Avatar
rws.1
see the 9th post(by 65GGVert) in this thread for a diagram
http://forums.corvetteforum.com/show...erature+sensor
Old May 19, 2008 | 03:20 PM
HillBilly Vetteman
OK...Thanks for the help guys...I guess I'll have to keep looking...still have no idea where that connector went.
Old May 19, 2008 | 03:22 PM
HillBilly Vetteman
Awesome. At least I know where to look. Thanks again.
Old May 19, 2008 | 04:11 PM
ZEEEEOOOOSIC's Avatar
ZEEEEOOOOSIC
Old May 19, 2008 | 04:25 PM
glerma's Avatar
glerma
St. Jude Donor '05
So how do you like the Vararam? Have you noticed any differences?
Old May 19, 2008 | 04:31 PM
Berger6696's Avatar
Berger6696
Yea, the A/C wont shut off!
J/K I'm sure after my install this weekend, I'll have some really good questions.
Old May 19, 2008 | 04:50 PM
glerma's Avatar
glerma
St. Jude Donor '05
That has nothing to do with the Vararam.. You need to add more grease to your muffler belt....That'l fix you AC problem right away!
Old May 21, 2008 | 07:06 AM
HillBilly Vetteman
So far so good. I can tell a difference accelerating at highway speeds. The car almost seems to "glide along"...I have to be careful because I end up going faster than I assume I am. It pulls real good.
Old May 21, 2008 | 07:12 AM
rws.1's Avatar
rws.1
Your Vararam install might just be the cause of your A/C problem....
Did you sort out that external temperature sensor yet......? If not one of the things it does is mess with the A/C..... The absence of a sensor sends a fixed temperature reading....
To Question about Vararam install.
