Who has drilled out around their foglights to let more air in?
#42
Not sure exactly how much I can thank the foglight holes but last week it got up to 95 degrees and I never had coolant temps above 202 or oil above 210 and as soon as I got above 40mph the coolant dropped to 190 in a matter of a few minutes. The holes in the LP inset and foglights make a huge difference on the lame Stage 1 Procharger cooling.
#43
Don't forget tahat you can remove the plate areas from the inside if you are hesitant to operate. I did the drill thing with 1 1/2" hole saw initially. It looked pretty good but I replaced them later with the Vararam set up.
#44
I have a set of modified bezels for sale in the parts section. Installed a Vararam and no longer need them.
http://forums.corvetteforum.com/show...089&highlight=
#46
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
St. Jude Donor '03
Existing threads receiving no replies for 45 days or more.
If an existing thread has not received a reply for a period of 45 days or more, members should create a new thread which is identical or similar in nature, rather than to post to the existing one.
Similar or identical threads created under 45 days will be considered a dupe, and will be locked accordingly.
Members shall not post to such threads as a means to resurrect them for discussion or as a means to be humorous.
