Nitrogen in tires
Old Sep 6, 2008 | 12:13 AM
jserio's Avatar
jserio
O.C.
Default Nitrogen in tires
I hear some of you guys having this stuff in your tires. What's the benefit and where do you get it?
Joe
Old Sep 6, 2008 | 12:27 AM
jrose7004's Avatar
jrose7004
It's smoke and mirrors!
Old Sep 6, 2008 | 12:58 AM
cheetah45's Avatar
cheetah45
jserio: The air you and I breath is 78% nitrogen. There is no advantage in using pure nitrogen in our tires. Professional racing uses it for 2 reasons(that I know of):
1: Less pressure increase when the tires heat up under racing conditions
2: Pit crew safety....nitrogen tanks store the gas under pressures at or above 2000psi....if you tried to compress air to 2000psi the oxygen in the air would ignite and the tank would explode.
I just purchased an 04 ZO6 and the dealer tried to charge me $195 for nitrogen servicing of the tires. I basically came unglued and started to walk out after reading the charge in the contract they wanted me to sign. Only after waving this "service" fee did I move on with the deal.
I have two 42 cu ft nitrogen tanks that costs me about $18 each to fill.
N Dennis
Old Sep 6, 2008 | 01:01 AM
bassman12350's Avatar
bassman12350
Old Sep 6, 2008 | 01:02 AM
itzza427's Avatar
itzza427
I have a Craftsman 30 gallon 150 PSI compressor,,,Good enough for me!!
Old Sep 6, 2008 | 01:20 AM
whylee's Avatar
whylee
I was told that using nitogen keeps moisture down in the tires to prolong the life of sensors in some vehicles.
I have seen some of these sensors pretty nasty looking after being subjected to moisture.
Old Sep 6, 2008 | 01:23 AM
jserio's Avatar
jserio
O.C.
Thanks guys. I kind a figured it was pretty much over-kill for street.
Old Sep 6, 2008 | 01:24 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
A search should bring up a 'few' threads on the great debate.....I wouldnt pay for it thats for sure.
Old Sep 6, 2008 | 01:45 AM
Riley P's Avatar
Riley P
Air explodes at 2000 psi? Come on now and think about it for a second. It will only explode if the vessel that contains the air can not support 2000psi (Scuba gear support pressures up to 4500psi). If it ruptures it will not result in an explosion because it is air, but the fact that it is under pressure. Nitrogen would do the same under such conditions. Nitrogen is a larger molecule than oxygen and as such will not pass through the matrix of the rubber as easily as the oxygen molecule, thereby maintaining the pressure in the tire longer. It also does not expand as much as air because of fluctuations in temperature. So when your tires are cold and at 30 psi, after driving on the highway and the tire warm up, they will be closer to 30 psi than a tire full of air. Moisture is another factor, I do not know a lot about this but most people are more concerned about maintaining the optimal tires pressure under different temperature conditions and therefore maximizing tire life. I believe where I am from, Nitrogen costs $30 to put in the tires, then $5 after to refill if you ever get a flat. Most shops offer this, it is not exotic by any means. That $195 charge is crazy, I would have walked out as well.
Old Sep 6, 2008 | 03:49 AM
CPT_Purge's Avatar
CPT_Purge
Using dry nitrogen means you're getting only a tiny amount of moisture in your tires. Basically nothing in terms of moisture. You're not going to have anything about explosions, lol, that was a funny post. I am a chemical engineer by the way, hope I can help in any way related on these forums as the guys have helped me out in finding my first C5.
Old Sep 6, 2008 | 08:24 AM
rws.1's Avatar
rws.1
The lowermoisture in Nitrogen is what reduces the pressure increase iwth heat. It also is better for the rubber and pressure sensors.
Costco uses only Nitrogen.. It's free.
If you can get it free it offers some benfits.
If you have to pay for it don't bother.
Old Sep 6, 2008 | 08:30 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
It was offered to me for an extra $25 but that has for the lifetime of the tires. So, anytime my tires where low all I had to do was drive 32 miles round trip to have it done. I'll stick with my modest Harbor Freight compressor...
Old Sep 6, 2008 | 09:17 AM
Oldvetter's Avatar
Oldvetter
Everyone is right, the low moisture is what accounts for most benefits, if any. Myth Busters did a segment on this, no benefit!
Old Sep 6, 2008 | 10:39 AM
04 commemorative's Avatar
04 commemorative
St. Jude Donor '17
Old Sep 6, 2008 | 11:42 AM
bassman12350
For those of us who have compressors (the small Sears 2 or 3 gallon ones included!), we can improve the "quality" of the air with which we inflate our tires by putting a water separator and/or filter in the line between the compressor and the air hose. It may not be as good as using pure nitrogen, but it will reduce the moisture content in the tires.
Old Sep 6, 2008 | 12:08 PM
jh61408's Avatar
jh61408
You could install a Air Dryer also into the system, As in a Refrigeration Dryer. They work very well at removing moisture from the compressed air. I used to use Nitrogen in my Motorcycle tires as you would get a big increase in Tire pressures after a long ride. Plus the added benefit of keeping the tire cooler also to some extent. I don't think it is a bad thing adding it, is it really necessary? maybe not but i won't hurt. I know they use in in Trailer tire and guys swear by it as they don't have blow outs now.
One thing that was brought up and has some merit is the wheel tire senors for pressure, As moisture could ruin them. But i think they wound have been designed to handle that?
Here is an example of a Dryer: http://www.zeks.com/Noncycle.htm
One thing you don't have to listen to is a Noisy compressor running when filling tires and other things, One standard nitrogen bottle will last a long time.
Old Sep 6, 2008 | 12:16 PM
pewter99's Avatar
pewter99
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
locked due to previous threads about this topic going south.
Please do not PM me asking to reopen it
To Nitrogen in tires
