Anyone Mag Red paint their rear plate frame Mag Red?
Old 10-15-2008, 06:24 PM
B-STOCK
B-STOCK's Avatar
St. Jude Donor '14-'15, '17, '19
Default Anyone Mag Red paint their rear plate frame Mag Red?
Tried to edit title so it made more sense but no can do.
I bought a can of Mag Red spray paint from GM. I was thinking of painting my stock black rear plate frame Mag Red. Anyone have a pic of a Mag Red C5 with the stock plate frame painted Mag Red? Photo shop would be OK. Thanks,
Mike
Old 10-15-2008, 06:40 PM
jrose7004
jrose7004's Avatar
Received 1,672 Likes on 1,295 Posts
No but I painted my frame Medium Spiral Gray on my MSG coupe. Thought I had a picture but I guess I don't.
Old 10-15-2008, 07:37 PM
Bill Vett
Bill Vett's Avatar
Painted mine Artic white to match my car....
Old 10-15-2008, 08:26 PM
dobewillie
dobewillie's Avatar
The white looked great shoot the red good luck
Old 10-15-2008, 08:31 PM
VetteHunting
VetteHunting's Avatar
Bill Vett was there any prep work involved?
Old 10-15-2008, 08:56 PM
OBSESHON Mark
OBSESHON Mark's Avatar
I think this is what you are looking for.
Old 10-15-2008, 10:49 PM
versatile
versatile's Avatar
Mike
Good idea! i'm going to get on that myself.
Old 10-16-2008, 12:09 AM
magneticmike
magneticmike's Avatar
Here you go: Bought from Kewl. Not sure if they're still around. Be careful... I ordered Mag Red 2, but they shipped me Mag Red 1. Returned it for the right color.....
Old 10-16-2008, 12:27 AM
B-STOCK
B-STOCK's Avatar
Thank you all. What should I do to prep the old frame? Did you guys clear coat also?
Old 10-16-2008, 01:31 AM
DeeGee
DeeGee's Avatar
Like Magneticmike I got mine from Kewl Auto for about $70. Its great quailty and a good match.
From what I read, the older frames were fine to paint. Apparently the newer model is difficult to get a good finish. If your frame is OEM you should be OK. The advice from the experts here was 3 or so coats of color and 1 or 2 clearcoat.
I've been painting some underhood panels and I have to say I've had trouble. Without a clean room I keep getting small bits of dust which ruins the finish. I've also speant way more on paint doing it myself. This may be one of those thats worth just paying the $$ Just a thought. Mind you, plenty of other members have done a great job so maybe its just me that totally lacks painting skills
Old 10-16-2008, 02:09 PM
Bill Vett
Bill Vett's Avatar
I used a filler/primer and did about 5 coats (the frame is grained) sanding between each coat with 600 grit. Then I shot 3 coats of color and wet sanded with 2000 grit then 3 coats of clear wet sanded with 2000 grit, buffed with 3M FinessIt, and then a coat of Zaino. Bill
Old 10-16-2008, 04:11 PM
steveblonde
steveblonde's Avatar
you can order them from GM i buddy got one for his C6 to match along with some other factory painted pieces,
Old 10-16-2008, 07:33 PM
B-STOCK
B-STOCK's Avatar
I bought a 5oz can from my local Chevy dealer for $15.
To Anyone Mag Red paint their rear plate frame Mag Red?
Quick Reply: Anyone Mag Red paint their rear plate frame Mag Red?
